Greg Rozar AKA- CubDieselFan
Old 08-24-2018, 09:49 AM
sorner's Avatar
sorner sorner is offline
Default "Big Red" 682 possible project?
I'm thinking about restoring this 682 I have sitting in my garage, the other half of my two-fer pickup a few weeks ago, and swapping out the non running KT17 Series 1 with an extra Magnum M18 (with wiring adaptations for the different ignition system) I have if I can get it running.
But I don't know if I'm going to. EVERYTHING is rusted on it. The worst of it is the lift handle button on top is rusted tight, I keep soaking it with PB Blaster and letting it soak for days and then tapping it with a hammer and it hasn't broken loose yet. I think the rust is all the way down inside, and I may never get it freed up.
I do have a question about the rear though... The main part of the rear is cast iron, but the axle tubes don't look like the other cast iron rear I had from a 149 or even the 73 I have currently in my driveway... They look like aluminum. Did IH use a cast iron rear and aluminum axle tubes at this point in production?
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 08-24-2018, 10:16 AM
cooperino's Avatar
Attachment 95309
Take the handle off, Mix up some acetone and ATF in a small bucket. Soak both ends for a couple days. Thats what I had to do with one of mine. If that does not free it up take the handle off and use a little heat. Patience is the key
You could also cap one end of a 3 foot long piece of pvc pipe and fill that to soak the whole thing!
Old 08-24-2018, 12:29 PM
sparky40 sparky40 is offline
I have a 1450 that came with a cast differential and aluminum axle tubes. Swapped out the aluminum tubes for cast ones.
72,147,149,169,1450w/Johnson loader,#2 cart, IH lawn sweeper
Old 08-24-2018, 06:34 PM
Yes. IH switched to aluminum axle tubes the QL series tractors, but kept the CI differential housing.
Thread Tools
Display Modes
