125 with 48in deck question
Got a pulley question on my 48in deck. I’ve been mowing all summer with the 125. Working all the bugs out, the one problem I’m having is it leaves a tiny strip of grass on the right side (discharge side). Also the mower belt seems like it vibrates a lot when mowing.
I got it from my brother in law who mowed a double lot in town for about 10 years. Said he put a new spindle in it last year (can’t remember which one). Went through the whole tractor, but didn’t have to do that much to the deck. Put new blades on it , and a different tension pulley spring. Anywho... took the guards off today so I could watch for anything while I mowed. I noticed the right and left side pulley are different sizes one is 3 3/4 the other is 4 1/2... this can’t be right can it?? Question is , I can’t find any info on the correct size. I’m thinking the 4 1/2 is correct? Dad has a 42in deck in the barn off 104, can I “ borrow” spindle and pulley off it if I had to?
Nate |
How are the baffles in it? Got a pic of the blade side?
I believe my 48” has the same smaller pulley on the right spindle. I think it was designed that way so the right blade spins faster to throw the clippings out and to help that blade cut better since it has to deal with the extra clippings from the other two blades.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
Early ones, +63-68 https://www.cubcadet.com/equipment/A...0-A/0075600003 had the same on both sides.
Later ones, '68-'71 & '71-'73 https://www.cubcadet.com/equipment/A...0-A/0075600005 And https://www.cubcadet.com/equipment/A...0-A/0075600007 Had the smaller one on one end Seems I recall reading about this in a manual or maybe it was a brochure once. |
Baffles are fine. It doesn’t leave a strip of un cut grass, just a strip of slightly taller grass. It’s not something I can’t live with, the vibrating belt bothers me more. I wonder if a new tension spring would help, instead of a used one...
Nate |
Nate |
Maybe your deck needs to be leveled better.
Thread Tools | |
Display Modes | |
