Part II Wheel Bearings Install
Hi again.
Thanks to all of you you passed on great info on the install. I am grateful even to those who ended up arguing. There were ball bearings all over the place and a lot of graphite looking grease everwhere. I cleaned it out. Put the new ones in dry. The bearings I bought were closed on both sides. Got them from a member who linked them. Thank you. They went in well. Now that I have installed the bearings how tight should the bolt be. I put it in pretty hard and the wheel is a bit stiff. Should it be in tight and wait for the process to loosen it up or back off the bolt a bit. Thanks. Mike |
Thank you. They are seated correctly. The wheels move with just a bit of drag.
The wheel shouldn't drag.
Check the spindle. Probably a burr on the inside (closest to the tractor) on the spindle that is keeping the wheel bearing from going all the way on. You don't want a ball bearing side loaded or it will eat it up. |
Ok, I got it.
I will pull the wheels and work on the spindle. |
I did not read the other thread so maybe it was already mentioned.......
But also check to see if some P.O. added a washer to the spindle before anything else is installed on spindle. |
Good point Double07, Never know what the PO might have done..
Some bearings that are not OEM tend to not work well, some do, some do not. Putting a small shim washer smaller than the spindle dia. on the end may help.
Thread Tools | |
Display Modes | |
