Greg Rozar AKA- CubDieselFan
Old 05-27-2018, 03:24 PM
boxccc boxccc is offline
Default 129 Front Power take off..follow up and new problem
Well I finally took the bull by the horn and got down and dirty. Removed the power take off clutch assembly and of course one of the notches of the clutch was broken off in addition to the two buttons up anterior where badly worn. When I removed the assembly from the drive shaft the key way had a bad divot and notched as well as the key itself badly worn.
I will provide pictures but my question is this: Can I spot weld the few divots and grind down to accept the bearing and pulley as well as re channel the key way slot without causing a further problem? Since I am a rank amateur, I hope I have described the findings the best I know and provide pictures to illustrate.
Thank You
Old 05-27-2018, 03:40 PM
I'd put a new key in it and not worry about the crank. If they key fits tight, and the set screws are tight it should be fine.
The one tooth missing on the disc isn't an issue. Fix whatever else is wrong and put it back together.
Old 05-27-2018, 05:35 PM
mortten mortten is offline
Book says PTO will operate satisfactory with up to 4 tabs missing as long as they're not grouped together.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
