Greg Rozar AKA- CubDieselFan
Old 05-24-2018, 09:07 AM
Cjbdvm04 Cjbdvm04 is offline
Default Deck compatibility question
Will this deck for a 127?
35819x
44c
0320023u
Old 05-24-2018, 09:27 AM
Leadslingingdaddy's Avatar
Will it what??????????
Old 05-24-2018, 09:29 AM
ironman's Avatar
ironman ironman is offline
35819x
44c
0320023u
Maybe color means alot?
Old 05-24-2018, 09:51 AM
No
44C is for an 82 series.
Old 05-24-2018, 10:23 AM
ironman's Avatar
No
'82 Series was St. Louis vs Milwaukee.
Seriously, you can look it up!
Old 05-24-2018, 10:27 AM
sawdustdad's Avatar
The 44c uses a 5/8 inch belt, your tractor PTO wants a 3/8 inch belt. Also, the mule drive (that mounts to the front of the tractor with idler pulleys) for the 44c (and 44a, 50a, 50c) decks have canted idler pulleys to accommodate the offset center drive pulley on the deck.
The 44a (and 50a) are similar decks with the narrower pulleys.
You can use the 44c if you replace the center pulley on the deck with a 44a pulley (for the narrower belt) and put a different mule drive on the tractor. I'm pretty sure a mule drive from a QL (e.g., 1000, 1250, 1450, 1650) will fit and should have the canted idler pulleys. You'll need a different PTO to deck belt.
I am in the process of converting a 44c to a 44a, for use on my 108. So it can be done.
All the parts are available--pulley and belt at various CC suppliers (I use ccspecialties.org) and the mule drive is probably on ebay or you can look at some of the used parts suppliers listed in the resources forum on this site.
I'll note that sometimes it's easier to just get a different deck, one designed to work with your tractor.
Good luck.
Old 05-26-2018, 06:43 PM
OldSkull's Avatar
OldSkull OldSkull is offline
Good description about A deck drive systems and "How to" C deck fitting! Thanks for the sharing Fred
Gilles.
1963 100 (red)/in storage
Old 05-26-2018, 07:52 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
You mean Frank, but I agree!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 05-26-2018, 08:29 PM
mortten mortten is offline
On a C deck you also have to move the left front hanger to the outer hole to make it a A.
Doug
QA-36A
42" blade
Old 05-26-2018, 09:22 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Part of the mower hanger needs to be modified for it to fit on a narrow frame.
http://www.cubcadet.com/equipment/AR...0-A/0074200004
Part #6 needs modifying at saddle bracket.. the part that slides over bar in the tractor frame.
Queen Of The Quietlines!
