Power Angle For A 125 Snow Plow?
I have a 125 with a snow plow that I have been plowing snow with for many years. A few years ago I located a Narrow Frame hydraulic lift and installed it. It works great!
Now, I'm getting older, knees are getting creaky and getting on and off the tractor multiple times to change the plow angle has sparked another thought: Has anybody ever put power angle on one of these plows? I know there is no factory kit for this, so there will be some fabrication involved. I haven't discovered an easy way to use the hydraulics of the lift to power a blade angle cylinder, and I don't know of a way to get hydraulic power out of a hydro unit of this vintage, so I've been thinking about electric linear actuators. I know that it seems like a lot to ask of a linear actuator, but Burden Supply lists some with fairly high force ratings, 500, even 1000 lbs. Would one of them hold up? How strong would it need to be? My thoughts go along the lines of anchoring it on the left side of the plow bracket and push/pull as far out the plow as it will reach (Burden has various lengths too). Has anybody ever tried anything like this? I'm strictly in the conceptualizing stage right now, Haven't bought any materials yet, so any thoughts or advice you may have would be quite welcome. Mr Moderator, if this should be elsewhere, please move it as appropriate. |
On the later model of tractors, they "Tee'd" into the hydraulic lines, added a Spool Valve, and front couplers. I suppose with some thought and ingenuity, that fabricating something like that for a NF Cub, could be done.
You could possibly run your lift off of your NF hydraulic unit and run your angle actuator off of the port for your rear end. With a cylinder (possibly with an extension attached to it) attached from the subframe to the blade, you could control the angle.
Anything is possible with some ingenuity and careful planning! Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
Are you talking about the hydraulic lines on the Hydrostatic unit?
I could tie the existing valve in one direction or the other, then put a pair of external spool valves to run both the lift and the power angle. But I'm not sure that the lift would supply enough flow or pressure to operate a cylinder for power angle. I read in the book somewhere that the unit only runs at 400 PSI. Then there is the problem of getting the return oil back to the unit. What "port for your rear end" are you referring to? Might be something there I'm not aware of. |
A simpler option would be to add a mechanical angle mechanism. I built this for my blade but since I now have front hydraulic remotes on both of my Cubs, I have no need for it anymore. It uses a choke cable to pull the lock pin and a push/pull motion angles the blade.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
