I looked at a Lowboy on the same day I saw the 982, but they wanted $3000! I don't see too many of those around that are in good shape for the money I paid. I just wanted a lawn mower with a little beef to it. Now I have two, but the Ford's...uh..."floating" deck leaves something to be desired, so I got the 982 with the Haban. I have tractors with loaders, a backhoe and an excavator for big work, like digging another pond....
Ok. So now I know.
deputyrpa, I got to tell you... I never saw a 1 acre pond coming when talking about working tractors. But it sure looks good. Did you have to line it with clay? |
NO. Actually, this is one of the few spots on my property that does not have clay on the surface. I hit blue clay 14' down. The bucket just sinks under weight in that stuff (it weighs 2 tons, though) I took about two feet of it out, and replaced about a foot of gravel for 15' total depth. I had to be careful - at 38 tons, you would be hard pressed to get that machine out of that clay because of the intense suction. That's my buddy's Hyundai 360 LC-7 that I borrowed. I have a smaller 15 ton Mitsubishi. It took me 7 hours to dig out the 2/3-acre pond with that one with its 3-yard bucket. Mine would have taken several loooong days.
deputyrpa, Thats a lot of diggin. Great pictures.
It's quality seat time Diz! The power of that machine is crazy, and I took it up the hill and removed some car-sized rocks from one of my pastures. My friend was extremely gracious to lend it to me. Here's a pic of him on the right with my father/son hunting buddies. My "second wife" neighbor is scooting away.
Just getting it moved back and forth 20 miles cost me about $1K, but as you can see, it was well worth it. My machine would probably be still in the hole! |
I was looking for a lowboy, but I couldn't find any localy. I did trip into a deal on a 106 by chance though. With work looking iffy and retirement in a few yrs. I guess I'll let the Low Boy for you younger cubbers. I'll just keep my 2 cubs in order the 106 with turfsaver tires & my good ole 147. PS: I was chased in again today hard t'storms. Hail yesterday. Check out the pics, the one of the deck was while the hail was coming down. ole 147 |
I own an I H 982 and also a 185 and 154 Cub Lowboy and I can state this as fact: the 982 will out perform the 2 lowboy tractors at cutting grass no matter how thick the grass is and I use them on my yard and my rental properties which can get out of control rather quickly. My Onan/Linamar LX790 replacement engine did great till it slung a rod and I'm not having much luck finding the compatible replacement so I'm going to go back with either a 25 or 27hp Kohler, both of these have stronger tourque than the Linamar did.
I H Pushmower,100,104,124,1450,1650,782,982,154 LoBoy,185 LoBoy,2 Farmall A's , Farmall H, and 8 IH trucks |
You could also go with a mag 20 also which would be an easier swap and should be as much torque as the 25 kohler command
I agree that M20 would likely be the easy swap, the tourque on the M20 and the CH 750 (model replacement) are way more expensive $1000.00 + and the 25 Kohler has 7.1 pounds more torque 39.9 than the M20 32.80 and the 27hp has 42.7 lbs and I want a new engine for the 982 and it is what I think would work well in it if the transmission can handle the power.
The transmission should have no problems what-so-ever handling the extra power. The hydros in these are extremely strong. The only failures I ever see in them, is the axles breaking. The transmission istself probably won't fail unless it has been very neglected. You can abuse them. Just don't neglect them.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
Thread Tools | |
Display Modes | |
