Greg Rozar AKA- CubDieselFan
Old 04-14-2018, 10:03 AM
Default Rear wheel width, option?
The IH manual says my 147 was standard with 8.50-12 rear tires, however, when I acquired mine it has 10.5-12 rear tires. Were those an option? Or did a PO install them at some point? (makes no difference really, I don't plan on changing them back, just curious)
Old 04-14-2018, 10:15 AM
10.50's were an option.
Old 04-14-2018, 03:41 PM
Thanks
Old 04-14-2018, 08:36 PM
Just about every 147 I owned had the 10.50 tires installed, I do believe it was standard equipment .
Up to 530 and counting...
Old 08-06-2018, 03:48 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Add on question...
Did the optional 10.5's on the 8.5 wide rims force the use of a 48" deck?
Or will the 42" deck gauge wheels still clear the optional tires and rims?
Old 08-06-2018, 04:30 PM
23x8.50-12 were Standard Equipment Rear Tires. 23x10.50-12 were Optional, per the IH Cadet Cadet Data Sheet.
Roland Bedell
Buy: Made in the USA
Old 08-06-2018, 06:45 PM
DoubleO7's Avatar
I understand that part.
Did the optional wider tires negate the use of the 42" deck and require use of the 48" deck so that the gauge wheels would clear?
Old 08-06-2018, 06:56 PM
You can use a 42" deck with gauge wheels on a narrow frame.
Old 08-06-2018, 07:47 PM
You can use a 48" deck with the wide wheels.
Old 08-06-2018, 08:10 PM
10.50's always look better, just check out this sexy behind! Kinda makes me wish my wife had 10.50's
Pap's 100
Restored 108
1211 Dual Stick
1050
