Greg Rozar AKA- CubDieselFan
Old 02-21-2021, 05:52 PM
Mark4470 Mark4470 is offline
Default Cub 100 engine
Hello guys,
This is a fresh rebuild on a k241. Do you guys think it will work on my cub 100? I know the muffler will need changed as well as the carb choke arm.
Thanks
Mark
File Type: jpg 46136D9F-0078-486C-BCF2-F8EB26D9F4C2.jpg (21.9 KB, 142 views)
File Type: jpg 7BD82F4D-9616-4C81-AFCC-F27026D008FD.jpg (28.9 KB, 139 views)
Old 02-21-2021, 06:41 PM
Looks correct but not sure if that eye bolt is a correct fastener for the head.
Up to 530 and counting...
Old 02-21-2021, 06:45 PM
Lol. I think he is an older guy, I assume it’s just for lifting. Thanks for your reply.
Old 02-24-2021, 07:43 AM
Go easy on us old farts.
If you wind up with that engine, as soon as the need for the eyebolt is past, be sure to remove it and replace it with a good grade 8 bolt torqued to specks.
FWIW:
I always question "it is all been rebuilt" as to so many, it means a spray can overhaul.
---Or a quick set of rings in a badly worn bore, and a crank pin out of round and tapered.
Some consider a "rebuild" as fixing it so it runs ok,kinda sorta, mostly.
I also question a hardware store eyebolt made for a clothes line, installed by a "rebuilder"
Warning Will Robinson, Warning!
-----Just saying, and don't "ASSUME" anything.
Old 02-24-2021, 08:55 AM
Ambush Ambush is offline
Not sure about the guy's rebuilding skills, but his painting looks good.
Old 02-24-2021, 07:16 PM
IHinIN IHinIN is offline
You’ll also need to swap out the 3 head bolts closest to the flywheel for longer bolts with spacers to mount the gas tank bracket.
Old 02-25-2021, 08:59 AM
The prone to cracking tank bracket mounts w/1/4" bolts via the engine tins.
Old 02-25-2021, 06:17 PM
Thanks for the reply’s. I’m putting the correct head on it.
Old 02-26-2021, 07:23 AM
ironman's Avatar
ironman ironman is offline
They're not talking about the head, they mean the tank mount.
Old 02-26-2021, 06:09 PM
Well, apparently my 100 has a later model tank bracket on it since mine uses the 3 head bolts and 2 flywheel tin bolts.
