Attachments for a 1606 (I'm a newb)
Hey everyone. I just bought a 1606, my first Cub Cadet.
I was wondering about attachments. I don't know anything about adding attachments. I would like to be able to add a blade on the front and add a hitch sleeve and maybe a tiller on the back. Are there any guides anywhere on exactly how to install a sleeve hitch? Are there any guides on exactly what attachments will work, etc? I assume I have to take off the mower deck for other attachments to work, right? Thanks in advance. Joshua |
Welcome to OCC............
Here is a list of attachments for the 1606: 190-364-100 45" Helper Spring Kit 190-364-100 45" Snowthrower (IH Design) 190-364-100 45" Two Stage Front Mounting Kit 190-364-100 Two Stage 45" Blower Frame 220 32" Lawn Sweeper 190-220-100 222 38" Lawn Sweeper 190-222-100 335 46" Triple Rear Bagger 190-335-100 336 46" Mower Garden Tractor 190-336-100 GT 357 38" Mower 190-357-100 358 44C 44" Mower 190-358-100 359 50C 50" Mower Garden Tractor 190-359-100 GT 360 50" Mower Adapter 190-360-100 368 10 Cu. Ft. HD Utility Cart 190-368-100 190-368A100 190-368B100 375 42" Snowblade 376 54" Snowblade 190-376-100 377 Blade Mounting 190-377-100 380 Sleeve Hitch 190-380-100 386 Sleeve Hitch Adapter 190-386-100 388 3 Point Hitch w/Spring Assist 190-388-100 38C Rotary Mower 400 8 HP Tiller 190-400-100 404 Adapter for 400 w/Sleeve Hitch 190-404-100 405 Adapter for 400 w/3 Point Hitch 190-405-100 425/425A 17 Cu. Ft. Utility Cart 438 Broadcast Spreader 443 Front Weight Bracket Kit 447 Rear Weight Bracket Kit 449 45" Snowthrower Spring Assist Kit 450 45" Snow Thrower 190-450-100 521 Utility Cart 653/653A 10 Cu. Ft. Utility Cart H42 Snowthrower Gearbox and Mounting H42/H48 Snowthrower Electric Chute Control Haben Snowthrowers H42, H48 353 354 H42 H48
I would suggest the best advice would be to find a tractor with a minimum of hydraulic lift. The blades can get heavy, the tiller can be a bear with the manual lift.
At the least, you should have this to help with lifting the tiller. 388 3 Point Hitch w/Spring Assist 190-388-100 You have a nice looking tractor there. |
Thanks Roland! Are these things for sale anywhere, or am I going to have to start visiting tractor shows?
Thank you. Here are a few more pics if you're interested.
https://www.dropbox.com/sh/q0723ykxh...nACO8Pbsa?dl=0 The only thing I have done so far is tuned up the engine, replaced some wheel bearings, and washed it. |
