Stock Clutch Spring Compression Length
Just a quick question, I'm rebuilding the driveline on my Cub Cadet 1000 with some non-stock parts but still using a stock spring. I'll be using a shaft collar instead of the coiled pin to set the clutch spring compression and I need to know the approximate compressed length for the stock spring. Uncompressed my spring is ~ 6 5/8". I would assume the clutch and length is the same for any of the quietline tractors.
Like an idiot I didn't measure the old setup before I took it all apart so if anybody has a clutch that is stock or close to it and knows the measurement, I would appreciate it. Thanks! |
There is a hole for the roll pin that keeps the spring in place under tension, that is where the collar should be.
My new driveshaft does not have a hole for the roll pin.
Ok, found all the old parts and mocked them up on the old drive shaft and it looks like the compressed length is about 5 inches on the nose.
If someone has a stock clutch and doesn't mind measuring their spring length to confirm that would be great. |
Just measure where the roll pin is from the end of the shaft that you have and that will set the length of the spring on your new one.
