Greg Rozar AKA- CubDieselFan
Old 12-14-2021, 10:52 PM
Ozcubowner's Avatar
Ozcubowner Ozcubowner is offline
What about getting a large bottle of fuel stabilizer
Oz
Old 12-15-2021, 11:04 AM
docmirror's Avatar
docmirror docmirror is offline
Originally Posted by EternalArianne View Post
One thing I don't understand is how my neighbor can just leave gas in all his stuff for months on-end and never have any issues they fire right up. Even his string trimmers. And I know for a fact he doesn't use ethanol-free gas or fuel stabilizers...
Here's a potential answer, but may not be accurate, I'll give it a try.
Ethanol will suck water vapor right from the air, and emulsify it easily over time. It's possible your neighbor keeps his fuel in a dryer local 'climate' than you, and possibly he keeps it better sealed against humid air.
When I keep Ethanol fuel in a gas can(rarely) I keep it in a well sealed 2Gal metal container. I also keep it fairly full, with a sealed top, and in a location where it isn't subject to a lot of direct heat or sunlight.
All access between the surface of a liquid like Ethanol and the absolute humidity(not standard humidity) around it will have a significant effect on how much water vapor is drawn by the Ethanol. Rel humidity is the saturation level, and the conditions for emulsion are greatest in the highest relative humidity, but the absolute humidity determines the amount of water vapor that can be absorbed.
Short answer - keep your Ethanol fuel sealed up in a dark place in a metal can for best results.
Old 12-15-2021, 01:04 PM
CubDieselFan's Avatar
Oz
Snake oil.
Old 12-15-2021, 06:09 PM
EternalArianne EternalArianne is offline
We actually store our equipment almost the same way - small stuff in a shed and the lawn tractors outside with a cover. Gas is kept in those red plastic containers (although mine is one of the old skool containers and his is newer).
He also mixes his own 2-cycle fuel and never has any issues, buying the cheapest oil be can get. I always buy the canned stuff for 2-cycle but I still drain it after use cuz I'm paranoid about cumming up the carb.
Old 12-15-2021, 07:08 PM
Then stop buying gas containing ethanol.
Roland Bedell
Buy: Made in the USA
Old 12-15-2021, 08:08 PM
docmirror's Avatar
Then only thing left is - you are cursed.
j/k
Old 12-16-2021, 05:37 AM
I've never actually had one of my carbs getting gummed up, I've just seen so many that were that I don't want it to happen to mine. Hence the initial question about fuel shutoffs.
I guess if I install shutoffs and run them dry I shouldn't have any issues. And if the fuel sits too long in the tank, I'll drain it and put it my car.
Old 12-24-2021, 09:50 AM
Frank1541 Frank1541 is offline
I started using Stable in all the gas that goes into 4 cycle engines a few years ago. I have no problem starting anything now, even after 8 months of storage. All the gas has ethanol. I do keep it in those Jerry can gas containers that have a good seal.
For 2 cycle engines I use the premixed stuff. Same thing, everything starts without a problem. YMMV
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
