Impulse buy
Good evening, I've been searching around my area for an older cub cadet. Finally found one. It's a model 149, it has seen better years but it runs. I was able to run it up the trailer and get it home. Took a little patience with the hydro lever on dash.
My plans are to get it mechanically sound over the winter. Future goal is a snow blower or plow. |
I like your impulses, looks good. Hope you enjoy the project.
Ken |
Good impulses.... Looks like the hood was salvaged from a 129. Red, white and blue!
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Very nice. What'd that set you back?
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
I got it for $300. The owner said it was a salvaged hood. He went over some issues it had. Nothing that can't be fixed. One is the axle release lever is gone. So that's a priority for me. It has 14hp original motor, run well, did back fire on shut down. The generator showed output, and steered fine
Figure tires all the way around. No noticable leaks at trans, tho I doubt brakes are working. I will need to find a diagram showing how the deck and hardware on the front mount up. Seems like something is off, deck does work, blades and lift, no bad noises. Will keep updates posted |
Looks pretty good to me !
What they said!
Approved.
I would say $300 for a 149 is a solid score
102 |
Thread Tools | |
Display Modes | |
