Greg Rozar AKA- CubDieselFan
Old 12-21-2021, 02:11 PM
Paullashley Paullashley is offline
Default Wanting to upgrade seat on XT1
Has anyone install a suspension type seat on thier riding mower? I have an XT1 I use for alot for moving dirt, leaves, yard trash etc. It's alot of uneven ground, alot of transitions from pavement to dirt. It get tough on the body after a few hrs. I do run agri tires which im leaning towards lower air pressure some to smooth the ride.
I figure some one has tried to mount something different then the stock type seat.
Thanks
Old 12-22-2021, 07:38 AM
Esteban Esteban is offline
I have seen a lot with fold down boat seats, that were comfortable & worked well.
https://www.basspro.com/shop/en/bass...E&gclsrc=aw.ds
Old 12-22-2021, 09:24 AM
Ag tires tend to have stiffer sidewalls, thus ride harder.
I use 5.5 pounds in my front tires and less in the rear, but it is an old skool 782 Garden tractor, with regular turf tires.
3-4 hours of mowing every week is not all that bad.
Old 12-22-2021, 03:49 PM
Farmall450's Avatar
Yeah, minus going and getting a several hundred-thousand dollar suspension seat and rigging it on, I'm not sure how much better you'll get than the OEM ones. You can easily add armrests to your seat, and 2022's seat has more cushioning than the previous models (could easily put that on).
Old 12-22-2021, 04:25 PM
I don't know how your seat is mounted, but if flips up, you can put a wheel barrow inner tube under it laid flat, and adjust the pressure to give you a redneck, 1/2 of an air ride seat.
Old 12-23-2021, 10:52 AM
I didn't think of the bass pro boat seat. All good ideas! I'd like something with an armrest. Guess I could look around and find a seat from an upgraded model with arm rests and still retain the seat switch.
I know the agr tires are hard, but the turf savers that were originally on it leaves a lot to be desired for traction. I've retired this from mowing.
Old 12-23-2021, 01:08 PM
Farmall450's Avatar
Your existing seat is ready for the CC armrest kit. Click the link on the top of this page, go to your tractor, and it'll be on there. The slots hold square nuts captive to fasten it.
Old 12-23-2021, 01:09 PM
Farmall450's Avatar
2 shoulder bolts in front, 2 springs in back. Not much has changed over the years
