#21
I finally got mine attached, but it shows up upside down. Had better luck in the old days with my desktop, now my IPad is also obsolete and won't accept upgrades. Progress is slow in this house.
#22
See: Images
#23
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
#24
#25
How much do those steel wheel weights weigh? I always prefer the looks of those to the plastic covered concrete ones. On my 1440 I bought some home made ones that are single cylinderical plates with rings welded on the outside that line up with the holes in the rims, they weigh in at around 40# for each side, there are four plates per side to get the 40#. They are crude looking but they don't protrude past the edge of the rim. The ones on my 1872 are the plastic covered concrete ones that protrude past the edge of the rim by a couple of inches. They are 50# for each side. I believe they are craftsman brand.
#26
I really don't care for the looks of the plastic ones but have 2 sets of those too.
#27
Yes, I know. They don't look as good as the metal, but obviously they weigh a lot more. Some of the guys on the Case, Colt, Ingersol forum made there own by melting lead from wheel balancing weights. I was thinking of trying the same thing, they are replacing the lead water service in my town, if I could get my hands on a couple of those, it would be plenty of weight. They used cut down propane tanks for the molds. The Case wheels have larger rims.
#28
Thread Tools | |
Display Modes | |
