Greg Rozar AKA- CubDieselFan
Old 08-21-2022, 08:36 AM
tweivoda tweivoda is offline
Default 1862 Front Axle failure
I was mowing last evening when the front of the tractor dipped to the left and I stopped suddenly. Initially I thought I just dropped in hole but such was not the case. The front axle had split so the tractor is resting on the ground with the left front wheel and power steering cylinder dangling. Of course this happened at the outer edge of the property and getting close to dark.
I have axle from an 1862 donor that I was going to put on my 782 when I did my power steering modification. I guess that project is on hold for a while.
I treat the old 1862 quite "gently" as she is 32 years old so I would have thought a front axle failure would be the last thing I would have to replace. Of course it's hard to know of its previous life as I've only had it about a year.
Now I have the task of getting the tractor to the garage without a functioning front axle, getting the mower off and replacing the axle. This tractor is Wisconsin where I have minimal tools. I think I need to set aside a weekend or two for the replacement project.
Anyone heard of these axles being prone to failure?
Old 08-21-2022, 10:18 AM
CubDieselFan's Avatar
Can you post a picture? Did the axle break or the steering spindle?
Old 08-21-2022, 11:21 AM
It was the axle about a third of the way in from the left spindle.
Old 08-21-2022, 02:29 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
I've heard a few of them crack and break. Cast iron is brittle, and if there is a stress riser, it will break there.
Old 08-21-2022, 04:18 PM
Mal adjusted mule drive pulleys wearing into the axle because of improper length belts is the main culprit in these scenarios IMHO.
Is that the case here?
The pulleys should be nearly parallel when properly adjusted.
Old 08-21-2022, 06:58 PM
RLause's Avatar
RLause RLause is offline
Jack up the front end, place a block between the axle and frame on the good side and drive it home
Richard
Old 08-21-2022, 09:26 PM
Now there is some advice a guy can write home about.
No better place to be broke down then in your own shop.
Ken
Old 08-21-2022, 09:36 PM
Steve N Mi Steve N Mi is offline
A couple of zip ties to hold up what has to go with the tractor plus
excuse me if this isn't necessary ( in fact tell me if it isn't necessary) but while you have the front jacked up you might want to remove the deck.
Old 08-22-2022, 01:30 PM
IHCubCadet147's Avatar
I broke a spindle on my 147 plowing my neighbors driveway once, about a 1/4 mile up the road. I put the plow down and sat on the fender on the opposite side and limped it back to the garage.
Old 08-22-2022, 02:05 PM
Find a fat chick to sit on the fender, and put her arms around Ya!!
