CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Old 09-10-2022, 07:00 AM
jsoluna's Avatar
jsoluna jsoluna is offline
Originally Posted by Carverlvr View Post
Where do I start? Does raising and lowering the deck affect belt tension or alignment? I lower it a couple notches to mow then all the way back up to store.
Yes, it does affect tension. There is less belt tension with the deck in the highest position on the 2000 Series in general. The 38 and 42 decks, particularly.
http://www.solunagarage.com
Old 09-19-2022, 09:53 PM
Carverlvr Carverlvr is offline
Is there anything I can do to address the loose belt at high deck setting? New belt, or spring?
Old 09-22-2022, 09:02 AM
Post some pics showing the top of the deck, the belt, the pulleys and the spring so that we can see what you have going on.
BX2660 with FEL & Grassanator
Old 09-22-2022, 07:54 PM
Ozcubowner's Avatar
Ozcubowner Ozcubowner is offline
The rear lift arms are angled from top to bottom towards front of mower so that as you raise the deck it moves up and back slightly to maintain tension on belt
If your deck is not moving backward as you raised it the first thing I would check is the front hanger , second would be the deck drive pulley tension spring
Photos would assist
Old 10-02-2022, 05:56 PM
Well, it took me forever to even get out to take a pic and not sure these will even help but here’s what I’m working with…
File Type: jpg A91DF531-3852-482F-B2DD-5FF483D60564.jpg (24.9 KB, 23 views)
File Type: jpg A063F0FA-E3E3-437E-8C25-49ED6F9A65E3.jpg (24.7 KB, 21 views)
File Type: jpg 8B4CEDED-0BF2-4CA5-BAEF-B5DFE0703238.jpg (25.3 KB, 23 views)
Old 10-03-2022, 01:58 PM
I don't see any obvious problems that would cause your problem. Just make sure that the tension-er is nice and free. The item in the red box.
File Type: jpg 8B4CEDED-0BF2-4CA5-BAEF-B5DFE0703238.jpg (25.4 KB, 16 views)
Old 10-04-2022, 05:53 PM
Sam Mac,
I went to mow and the deck belt slipped off again. Every time it happens I notice the tension spring has also come off it’s post but assumed it was because the belt was off the pulleys…now wondering if the reverse is the cause. I dropped the deck and yes, the tensioner is moving freely and I closed the end loops on the tensioner pulley spring just in case. I also cleaned under the deck while I had it down but also found I’m due for a new belt. Is this cause or effect?
File Type: jpg 516D2C2A-3FF1-4A94-BF20-FE98BADCA327.jpg (34.5 KB, 8 views)
File Type: jpg 56D16F97-C408-4BD2-A05A-455BA94DEC55.jpg (31.6 KB, 8 views)
Copyright ©2000 - 2022, vBulletin Solutions Inc.
