Cub Cadet LT1050 that blows fuses
Hello, i have a cub cadet lt1050 that keeps blowing the 10 amp fuse after start-up.
Any ideas thanks |
First, welcome to OCC.........
With the limited information given obviously you have a short. It could be a component or bad wire(s). Need more information.
Lt1050 blowing fuse
Hello, i replaced the 10 amp fuse with a 15 amp got very hot tried to trace wires for headlights, ordering a new ignition switch,motor runs better when i unplug wire harness from engine any ideas.
Thanks will |
Your going to need to pull up the wiring diagram and start tracing wires. No idea what the "10 amp fuse" is for.
There are three different Wiring Diagrams for this model. Can you narrow it down by looking at the Model/Serial tag and displaying the Factory Code, ie: 13AXXXXXX. ??
Main fuse shorting out
My lt 1050 cub cadet keeps shorting the main fuse after start up any known problems on this tractor of where i should look first?
Thanks will |
Short
I will get info for you
thanks |
