If the engine is not stuck, the tires hold air and all the major pieces and parts are there, it would be worth the $175 in my area.
FWIW, it appears to be in better shape than my 123 was when I got it. Also, those rear tires are the same tread pattern that is on my 123. I always assumed they were original, but I can't prove it. |
Here is what 150.00 gets you in jersey...
Holy cow... that is a nice machine for $150. Goodness, the seat is in perfect condition! The 123 isn't very common around here, and the only similar machine I've seen is my friend's 122. I will ask the seller if He has any of the attachments for the tractor.
'70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
You better grab it before someone else does.
More important, it's highly effective. There are three things needed for an ICE engine to run. Compression, a timed spark(non-diesel), and a suitable mixture of fuel and air. It has been my experience that a previously running engine will have enough compression to fire if the spark and mixture are present. Since the spark requirement is mostly binary, either there or not there, that leaves testing with fresh fuel. Carb cleaner is an excellent fuel source, plus it helps clean the carb inlet in the process. I would be - amazed if there were any negative repercussions from a few spritzes of carb cleaner into the intake while cranking. Amazed. |
Now please guys, don't start a fight in my thread. Only point of this was to ask y'all if this 123 is worth purchasing. By the looks of things, it seems everyone thinks it is, so I will probably bring it home soon enough .
Kinda glad I got into this hobby and not that to be honest. I'll tell you guys what happens depending on if I get the machine or not.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
Looking forward to an update on your 123 find. It looks quite good for the price, I know I paid 250 for one years ago not running and missing some small parts
IH cub cadets 800x3,1000,1100,1200x2,1250DS,1450,1650DS, 71,122x2,123, 73x2,106,107,126x3,127,147x2,86x3,128,149, 169x2 ,Original, cadet 55, to name a few CCC machines 1282,1050,2072,1535,1440 |
Well, I have made the decision, and the tractor will be coming home with me soon. In the meantime, because I know you all like pictures so much, here's something from today: Our 1863, parked next to my new O. A bit hard to see, as it was already getting dark out (darn winter is coming fast!) Quite the difference over the years, but one thing that remains the same is...
The style of rear rims! IMG_20201024_181930.jpg IMG_20201024_182003.jpg I also found this website and was very disappointed that of all the NF's, it didn't have any info on the 107!! https://www.tractor-specs.net/cub-cadet-lawn-tractors
