Greg Rozar AKA- CubDieselFan
Old 10-19-2021, 03:15 PM
Sc120sc Sc120sc is offline
Originally Posted by Cubcadet_107 View Post
The head gasket soaking used to be the normal procedure, however since the manuals were printed 50 or so years ago, new designs of head gaskets have been made that are a lot better than the old old ones, and they do not require soaking in water.
Head bolt torque is 30 ft lbs, start at 10 or 15 and work your way up to 30 in increments of 5. Be sure to do this following the correct tightening pattern, which can be found in the service manual.
I do not know the specific specs on oil pan bolt torque.
I found the pan torque around 25 to 30 lbs.
The rod bolts say 280 inch. That converts to about 23 to 24ft lbs if its ok to do that
