Comments Please on thickness.
The 3/16 is too thick and has to be milled to more like 1/8 inch. But that's what others say to use. I think the 1/8 inch would work better. I just got done doing my first set of pads and had to reduce the pad thickness by about half.
OK...Much thanks.
What are you using to glue the material on? My 126 is gonna need a brake job too.
'71 IHCC 126 - sleeve hitch+assist, 42" deck '87 CC 1872 and 1811 - Haban, 44C '90 CC 1535 6 speed - 46GT "Dumpster Find" '96 CC 1863 - 54GT '79 JD 400 - 60" deck "Projects" '67 123, '65 102 |
That was going to be my next question also...
Any slow cure (=high strength) epoxy.
Just finished up the brake job on the 108 and the 1/8 material worked perfect. Thanks sawdustdad. For glue I used an epoxy from JB weld that was in a double syringe type of deal. That's all for now.
voltage at points ?
What should the voltage reading be at the coil and points ? I am getting about 4 volts and 12.8 at the batt. Have filed the points and they look good but with 4 volts to the points , no spark.
Thread Tools | |
Display Modes | |
