PTO only works in reverse mowing LT1046KW (13WF93AT010)
Hey all, I'm having a problem with my PTO on my 2013 Cub Cadet LT1046KW (13WF93AT010). It won't activate the blades unless I switch the key to the reverse mowing position and press the button. Then the PTO will activate the blades.
I pulled the switch and tested for continuity and the switch appears to be good I've checked the connections and they look good. Did some research online but I couldn't find anyone with the same problem. Hoping it might be an easy fix as I'd rather not have to buy a new PTO clutch. Thanks in advance for your help. |
First, welcome to OCC..........
Sorry to say, but you will need to replace the Key Switch Module. The 725-4227B is replaced by --> 925-06119C or Stens 430-220.
Well that's better than the PTO clutch.
Good news. I pulled the ignition switch and it was all gunked up with dirt. Cleaned everything off, sprayed a liberal amount of electrical contact cleaner, put some dielectric grease in and reconnected everything. PTO works as it should now. Thanks again.
