Old 04-20-2016, 08:33 AM
kuleinc's Avatar
kuleinc kuleinc is offline
Any tips on driveline pin install? Split tractor again or try to do it in one piece?
Check out our videos and our instagram!
1967 Cub Cadet 123 and 122 | 1987 Vanagon Westy with 1.8T engine | 1986 John Deere 330 | 2007 Yamaha Grizzly 450 | 2007 Yamaha Wolverine 450 | 1996 Yamaha Blaster | 1988 Kawasaki JS440 | 1991 Yamaha Super Jet | 2006 Kawasaki STX-15F
Old 04-20-2016, 08:51 AM
ironman's Avatar
ironman ironman is offline
Originally Posted by kuleinc View Post
I was putting my tractor back together, and I think I did something stupid. I forgot to press the pin in the end of the driveshaft for the engine do I need to split my tractor to put the pin in or can I just try to pound it in with a hammer in place?
I ask because someone warned me to support the end of the hydro when pinning the flex disc couple on it...
I would be guessing here because I don't have anything available to look at, but I am thinking that you could unbolt the engine and slide it forward enough to dis-engage it from the engine hub, then support the driveshaft from below, perhaps with a length of 2 by 4. If there is room to hammer, that might work.
Old 04-20-2016, 08:52 AM
I wouldn't split the tractor again, I'd take the 4 bolts out holding the engine in and slide it forward to give you a little room to work. Make sure you support the driveshaft with a block of wood or something so it doesn't get bent will installing the pin.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-20-2016, 08:16 PM
Originally Posted by ironman View Post
The part in this picture labled "pivot pin" goes through the hole in the part labled "brake lever". The part labled "adjusting screw" must be completely taken out. When it is in, it goes through the groove in the pivot pin and keeps the pivot pin from coming out. Alot of rust may have formed on the pivot pin, so soak it real good with penetrating oil before trying to tap it out. The part in the picture labled "retainer" is where your "O" ring is. Once you get all the external parts off nothing holds it in but it can be a bitcz to get out. Once again lots of penetrating oil and prying.
These are the parts in ironman's picture. Original parts on left, replacement on right.
That would work although if you get that far, it's only two more bolts to take it out.
One end of the driveshaft pin hole is reamed on size so it's easier to start the drive pin. "Murphy" makes sure that will be on the bottom first try
Old 04-20-2016, 10:44 PM
kuleinc's Avatar
It started ok, but I'm using a 5 pound hammer and a block of wood and the pin is mushrooming. I just removed the drive shaft and will use vise at work to press it in...
Old 04-20-2016, 10:47 PM
Need another pin?
Old 04-20-2016, 11:00 PM
Are those pins hardened?
Up to 534 and counting...
Old 04-21-2016, 08:36 PM
No, not hardened but a strong steel alloy.
Old 04-21-2016, 08:49 PM
They original ones I have never mushroomed,they must be harder.
Old 04-21-2016, 11:12 PM
kuleinc's Avatar
The original one I hammered out broke like glass, Jeff's does seem softer. I'll keep an eye on it and report back after a few weekends of mowing. Also, I got it back together and fired it up, no more noise!
