Old 04-25-2014, 04:42 PM
Dave R Dave R is offline
Default Just a tip...
Before you run the 149 much, raise the hood, and get an allen wrench that will fit the s/generator pulley on the crankshaft. It take a long allen wrench, but you can reach through a couple holes there and tighten the heck out of it. Miine rattled after I had overhauled it, worked itself loose. I took all the PTO clutch and the s/g pulley off and put in a new key and new allens. Tightened it all back up and intend to keep an eye on it. Its a lot easier to do that than to take the freakin pto clutch and all that off again.
Just my .02 cents worth. You'll have the ole girl running good and working in no time.
Dave in SW Missouri
Old 04-25-2014, 04:46 PM
Dave in SW Missouri
Thanks, will do. S/G's are kind of new to me.
Old 04-25-2014, 06:05 PM
Yeah that reminds me, I need to check the one on my 128.
Old 04-25-2014, 07:06 PM
105_Tom's Avatar
105_Tom 105_Tom is offline
Another great thread, Sam. I love my 149 and would have a hard time trading it away for anything. Soo stout and easy to work on. I also had the front pulley spin off after rebuilding, twice now even with Loctite and cranking it down as much as I could stand. Once you do one PTO clutch, it's like riding a bicycle for any future endeavors. You have an earlier 1x8/9 series like mine with the serial # still on the rear end and the non safety-stop, non-interlocked PTO. Mine is #401xxx...
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Old 04-25-2014, 10:23 PM
OffTime's Avatar
OffTime OffTime is offline
I'd like to see the thrust bearing on the PTO if you can post some pics.
X2! Chris (non-member friend) and I have been looking at that as viable option too. I haven't taken the time to do any more than just think about it. Would like to see what bearing they used.
I will try to post some pics maybe tomorrow. Maybe I should just start a new thread.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 04-25-2014, 10:26 PM
OffTime's Avatar
Originally Posted by sawdustdad View Post
I solved my 149 drive shaft situation a little differently..just throwing it out there for those with fewer skills than Sam...like me.
That is how mine was fixed. I refered to that in an earlier post. The difference is that yours looks like a much better fix than mine.
Matthew B
Old 04-26-2014, 02:19 PM
Good day today! Finished washing pig pen. PTO parts showed up.
Old 04-26-2014, 02:30 PM
Good to hear Sam!
I think that is hilarious you calling it pigpen!
Old 04-26-2014, 04:31 PM
Good to hear Sam!
What would you call it? Anyway it cleaned up decent.
Old 04-26-2014, 04:42 PM
bkw3614 bkw3614 is offline
Sam, I don't mean to splash any cold water on your drive shaft idea, because it looks as if it is a good one. I am just wondering if that shaft needs to be balanced because of the probability of getting something a little off center in the fabrication/welding process? It seems to me that if anything is off at all on that, the drive shaft would vibrate horribly.
