Old 06-19-2014, 11:07 AM
IsaacSchuler's Avatar
IsaacSchuler IsaacSchuler is offline
Where can i order a cheap brand new seat all of them are over 130 dollars
play like you're in first work like you're in second
My Facebook Group
Old 06-19-2014, 12:21 PM
if you have, and want to keep your original seatpan..?? you can order a replacement seat cushion from colemans military surplus for 9.95$ and then some trim lock..with a little trimming and some grunting youll have a new seat..not quite like the original, but dimensions are relatively the same and the price is right...thats how i did mine, if youve seen the 1250custom/restoration thread...?
Old 06-19-2014, 03:16 PM
Bob95065 Bob95065 is offline
I have a 1450 that was rode hard and never put away. The original seat is cracked bad but the pan is good. Thanks for the link. Does this cover come with padding?
I'll have to search the web site for anything else I can use because I hate paying $17 to ship a $10 part.
Where did you get the trim lock?
Old 06-19-2014, 07:21 PM
It does come with the foam padding adhered to it..i had to trim some off the top and the bottom front to make it fit..large serrated kitchen knife or electric one would work good, just be careful not to go through the cover!!!! As i said its just a touch bigger than the dims given on their website, and not perfect but it does work!! I ordered the metal reinforced trimllck from mcmaster carr...i forget what size and style....also, colemans does make you order around 20bucks worth, so get yourself a g.i issue baclava for those cold plowing days!!
Old 06-19-2014, 07:30 PM
larry03061976's Avatar
larry03061976 larry03061976 is offline
Looks really good! Nice job!
Old 06-20-2014, 11:28 AM
Great job! Your 1250 looks nice!
Old 06-26-2014, 08:49 AM
My Facebook Group
Old 06-26-2014, 08:52 AM
My relief valve on my hydro pump is leaking its leaking out of the small hole and it cant go in reverse how do i fix it. I know a guy in ohio rebuilds them but i don't know if he still does it or not. is there a place i can buy one cheap? because used ones aren't guaranteed to not leak. And new ones are expensive its the left one thats leaking.
My Facebook Group
Old 06-26-2014, 09:02 AM
605 Furnace Rd.
Conneaut Ohio 44030
Phone: 440-499-5813
Email: mark.machtech@gmail.com
E-Bay add
$35.00 each plus $4.95 shipping ($4.95 flat rate regardless of amount)
That's both valves rebuilt for only $74.95
I've had him do about 8 pairs so far and no problems
Old 06-26-2014, 11:22 AM
Your 1250 is looking nice.
