Old 01-01-2014, 07:02 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
got the wire today and that did it. the welds are beautiful. here's what the wost part of it all is... the wire i was using the first time wound up being .025 i had no idea i even owned .025. it must have been the roll i got with my PM-135 10 years ago!! i had the machine set up for .035 no wonder why it wasn't working correctly. its hard to tell just by looking at the wire but when you put them next to each other you can see the difference. im glad it was just something stupid and not a problem with the machine.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 01-01-2014, 07:09 PM
ken6x6's Avatar
shot of the Power Mig 216 with a test weld on some 1/4'' scrap.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 01-01-2014, 07:23 PM
shot of the Power Mig 216 with a test weld on some scrap.
Good to hear it was just something "silly" that was the problem. I have .023 and .035 wire for my Hobart Handler 187 and change the tip ( not the liner ) plus the heat/wire speed settings when I switch wire.
That looks pretty good.
Old 04-23-2015, 01:32 PM
cnsolutions cnsolutions is offline
I have a Millermatic 210 with spool gun and dual tank setup, Miller Syncrowave 180 TIG/Stick and a Hypertherm 40 plasma cutter.
Cub Cadet 2284
Bobcat S220
Allmand TLB225
IHI 35NX2 Excavator
Ford 661 5 Speed Double Clutch
Old 08-09-2015, 05:06 PM
freedhardwoods's Avatar
freedhardwoods freedhardwoods is offline
Here's the old Lincoln I got for $25. It does what I need. Someday I might get a mig.
I used a big Miller mig when I was a welder in a trailer factory years ago. Don't remember the model.
Old 08-29-2015, 01:30 AM
Bill410 Bill410 is offline
Have a couple welders. Little Lincoln 130 mig that sees a lot of use and an OLD Lincoln Idealarc 300 set up for stick and tig. The idealarc is a monster! About the size of a mini refrigerator and runs on a 100 amp breaker! It doesn't move much either, with old wire and transformer circuitry, its gotta weigh every bit of 400 lbs!
Old 08-29-2015, 08:27 AM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
snap on mt 2500 mig welder,115 volts with high and low settings. i have owned it for almost 10 years and it has been great
Old 09-19-2015, 06:37 AM
brucepts brucepts is offline
I have an old Harbor Freight 110v DUE MIG-II probably 30 yrs now? Looking to replace it with a 220v model if I ever have some spare $$$'s. I've run lots of wire through that machine.
This past year picked up an Eastwood TIG 200 and I'm trying to learn how to weld with that now. Always been something I wanted to learn . . . kind of a "bucket list" thing
I never will be a professional welder but can stick things together without them coming apart! And for my projects it works for me
Old 09-19-2015, 06:25 PM
I don't think I posted my Hobart AC/DC Combo machine in this thread. It's an arc and tig welder plus a plasma cutter. I need to locate a plasma torch/cable since this one is beyond shot.
I also picked up a TEC water cooled tig torch ( on the left ) and a "few" consumables too.
Old 09-10-2016, 10:33 AM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Default welders
Miller Syncrowave 300 with cooler under it,Miller matic 200 with spool gun,Miller Big 40 Diesel with Ac and DC output plus power 220 3 phase
