Old 09-19-2011, 12:58 PM
CC1650Dave's Avatar
I've never seen that tunnel around a hydro fan either. Is it a plastic tube?
Old 09-19-2011, 01:28 PM
My son's 125 has a steel hydro fan cover. It's part #6 on parts look up.
http://www.partstree.com/parts/?lc=c...&dn=0019250008
Old 09-19-2011, 09:13 PM
Sugarmaker's Avatar
Default 147R hydro fan cover
Like Duke mentioned. This is a steel fan housing/ guard for the hydro fan on the 147. It bolts to the underside of the tunnel with four pan head screws. Only goes on one way and is offset to one side of the tunnel. I have several shots at various places during the restoration. Blasting would have been the easiest way to clean this piece. I choose to use aircraft remover and lots of hand work.
I put a lot of effort into trying to clean all the parts best I could, and not get too carried away. I plan to take this tractor out and mow with it next season.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 09-20-2011, 10:41 PM
Sugarmaker's Avatar
Default more tools
Couldn't find any one with a tap and die set of 3/4-16 thd for chasing the spindle threads. So I stopped at Sears on the way home and splurged on myself and bought a set of tap and dies that go up to that size.
Hauled three more loads of wood tonight to the house with the 86 and wagon. I have to get some pictures posted for you guys on that subject.
Anyway I did chase the threads on the spindles for the deck. The seals will be in on Thursday from Kaman.
Also traced all the wiring for the 147R and will try to spruce up/ repair and use a set of wires that were on it. Most are in pretty good shape.
Haven't heard from the engine machine shop yet. May give him a call tomorrow.
Regards,
Chris
Old 09-21-2011, 12:56 PM
Sugarmaker's Avatar
Default Engine work (machining)
Called the machine shop and should be able to pick up the block, valves, piston and crank Sat morning!
Looking forward to getting started on the assembly work next week.
Regards,
Chris
Old 09-21-2011, 01:39 PM
Regards,
Chris
Awesome news Chris!
Old 09-21-2011, 02:02 PM
Cool deal, Chris!
Old 09-21-2011, 07:47 PM
LarryW's Avatar
LarryW LarryW is offline
Great News!
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 09-24-2011, 08:48 PM
Sugarmaker's Avatar
Default 147R engine rebuild under way.
I (we) picked up the engine block turned crank, reground intake valve and the piston and crank bearings from the shop machine shop today. The (we) part is that my Grandson Mike did the driving for me all day he just got his permit this year and he handles the big F250 real well!
The cost of the machining was $85 total I thought that was reasonable.
Brought the block home and scrubbed it with very hot soapy water to remove all the machining fluid and residue. Dried and set aside.
Will start the cleaning and re assembly this week.
While waiting for things to settle down I did find some information on the deck spindles and found I was missing the split ring (cone) spacer in between the two inner races. Approx .225 inch thick. I found one on the bench and made another from a inner race of a old bearing. Here are some shots from a few days ago when I assembled the new bearings and seals. Yea I got a little carried away with the red paint they were supposed to be off white like the deck. Well I guess this deck will have red spindles
Yes I did have a gray helper, She wanted some attention too! Her name is Gracie.
Also looked a a very well used 125 today, with deck and snow blower. Any thoughts on a 125 unit? I need another like a hole in the head. PO has let this one slide and it needs touched all over tires are all flat, and looks like real rough where it sets. He did some engine work then said it over reved he shut it down and never got back to it???? It is setting inside a building with a dirt floor. Could be that diamond in the rough: or just rough
Regards,
Chris
Old 09-24-2011, 09:57 PM
Great pics, Chris! Thanks for the update.
