Old 02-09-2017, 11:30 AM
OldSkull's Avatar
OldSkull OldSkull is offline
Totally yummy!
Gilles.
1963 100 (red)/in storage
Old 02-09-2017, 11:45 PM
Good progress Fred. Tins look good...
Old 02-10-2017, 09:31 PM
farmall fred's Avatar
farmall fred farmall fred is offline
Thanks Todd, The tins did come out very good. I let the epoxy cure over night and I sprayed three coats of 2K primer surfacer on all of the parts that will be painted red. I will let them cure for two days before block sanding and sealing for final paint. I then finished disassembling the frame to prep for paint. I got a shock when I removed the brake cross shaft, it came out in two pieces so I spent the rest of the day making a new one and de greasing some of the parts. Maybe I will get lucky and have it all painted by next weekend.
Have a good weekend, I know I will the beer is cold.
Tom
Old 02-10-2017, 11:44 PM
Tom
Never a dull moment...
Old 02-15-2017, 07:01 PM
I decided to get the frame prepped for paint before painting the tins. I did not want to try to protect a bunch of freshly paint parts from dirt and potential scratching due to extra handling. Upon removing the paint I found some cracks in the frame near the axle mounting holes and many of the mounting holes were all wallowed out. I tig welded the cracks and after making a drilling jig I welded all of the mounting holes shut and re drilled them. After removing all of the paint and sanding it down I washed it with wax and grease remover and coated it with three coats of reduced black epoxy primer that has a UV inhibitor so it can be used as a top coat. It dries to a nice semi gloss finish. I have used in the past on auti frames and under hood parts. It makes a great durable finish. Here are the required pictures.
Have a good one.
Tom
Crack in frame and wallowed out front trans mounting holes. On the left side there were also cracked around these holes.
Wallowed out axle mounting holes.
Crack tig welded and holes filled with weld.
Drill jig bolted in place.
Stripped and cleaned frame ready for paint.
Side view of painted frame.
front view of painted frame.
Next I need to paint all of the brackets, pedals, dash pedistal and the front axle so I cam final assemble the chassis. Hope to get them painted tomorrow.
Old 02-15-2017, 08:21 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
WOW!! Nice work on the frame... the drilling jig was a great idea!!
You are going above and beyond on this build! I am having fun following your progress!! It makes me proud to see someone who still has pride in their work and wants to do it right the first time!
Too many people rush and cut corners these days and wind up with inferior finished products! But you my friend will not be one of these people!
Jay
Proud owner of the following:
Old 02-15-2017, 09:00 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Very nice work there, can't wait to see the whole tractor reassembled.
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 02-15-2017, 10:29 PM
Thanks guys, I am spending more time and way to much money on this one as it will probably be the last grass killer I will own. I figure if I do it right it will outlast me. It will be my version of what the Cyclops should have been. I will be glad when I can call this one done.
Later
Tom
Old 02-15-2017, 11:22 PM
Nice work Tom.
It is good to see the extra work put into the project, as Jay mentioned, good to see it done right the first time, and not cutting corners to just get it done.
Well done thus far...
Old 02-16-2017, 05:20 AM
Dirty Steve's Avatar
Never saw a jig used to re drill the holes in a frame. Excellent the idea!
