#71
![]() Quote:
I know the feeling, I'm ready to go as well haha. Quote:
#72
I do both. I put half my seed on before I core, then plug the pooty out of it and spread the rest. Then I chain a pallet to the rear and drag it real good. Some say not to core and seed cause the seed will not live if it falls in the holes. I have seen it come out of the holes and I figure it has a good start on a deep root that way. My holes can't average much more than 2" deep, heck it's pretty tough to disc it in less than that and billions of acres of pasture have been disced in and came up great. I think even moisture is the most important thing to do in getting good germ.
73 149, 73 109, 71 128 with sleeve hitch, decks for all with a 44C on the 149 as the daily mower. front blade and IH rock rake |
#73
Finally had some rain last week to soften up the yard. So over the weekend I got out the de-thatcher and scratched into the dirt to pull up the crabgrass so I could cut it nice and low. I had a couple 4" block on the dethatcher so it got into the dirt an inch or so. Spread some seed over that part of the lawn been watering it and now I'm standing by for some growth to fill in the sparse areas.
#74
![]() Quote:
#75
We have been about 70* daytime high and 50* night time low the last week or so. Looks like we are getting a little cooler for a couple days then bouncing back up a bit over the next 10 days or so.
Thanks for the tip on quinclorac, I'll read up on it. I'd like to try to keep the crabgrass away from that area of the yard if I can. I will probably wait until spring to put down anything unless the product recommends otherwise. |
#76
![]() Quote:
![]() There are many pre-emergents out there which are very effective, not just against crabgrass but most other annuals. I just purchased a jug of Prodiamine , bit expensive at $65 but it should last me about 10 years, so much cheaper and much more effective than buying stuff at big box stores. I plan on hitting it with pre-emergent early spring, and anything that gets through I will hit with quinclorac and 2,4-D. This should in essence break the annual cycle since there will be no more plants to produce seed for the following year, but there's always dormant seed in the soil so I expect to be doing this for a while. |
#77
Just remember that crabgrass is a biennial, so you have to apply for two years straight. If you don't, you are back to square one.
#78
![]() Quote:
#79
Finally got some noticeable sprouts from the new seed, I was getting a little anxious that I hadn't seen anything in 10 days.
Wondering if I should hit it with fertilizer meant for new lawns to help the overseed or meant to help with the fall root growth... decisions, decisions!! |
#80
![]() Quote:
