Old 04-24-2014, 10:44 PM
OffTime's Avatar
OffTime OffTime is offline
That drive shaft idea is something that I think should catch on. My 129 has the rubber drive disc on both ends of the shaft. Some way in the conversion to the disc, the shaft didn't get centered and it wobbles a little. I don't like it. Thanks for the idea.
On the PTO clutch, sometime in the history of the tractor the little brass button was replaced with a small full cage ball thrust bearing. I think whoever did that was a brilliant cat. Once in a while I pull it out and add just a touch of grease. I've never rebuilt the clutch, so I don't know any specifics on what they may have done to make it work, but it works great.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 04-24-2014, 10:48 PM
Looking good Sam!
Old 04-24-2014, 11:25 PM
Very nice, Sam!
Old 04-25-2014, 01:22 AM
Great thinking there Sam
Old 04-25-2014, 01:50 AM
Looking good Sam! Wish I was retired so all my projects could progress so fast!!
Old 04-25-2014, 08:48 AM
I'd like to see the thrust bearing on the PTO if you can post some pics.
Old 04-25-2014, 12:51 PM
X2! Chris (non-member friend) and I have been looking at that as viable option too. I haven't taken the time to do any more than just think about it. Would like to see what bearing they used.
Old 04-25-2014, 01:24 PM
esarvey's Avatar
esarvey esarvey is offline
Default D-Line is fine !
U not just a Purdy face !!
Progress for today. The drive coupling on the engine was toast, so since the drive shaft was also messed up I came up with a different solution. My shaft will be part 149 and part 2000 series. All I need to do now is drill it for a spirol pin. Happy Happy Happy
DaDuke of
2145,1864,1811,1810,1541,1330,1210,1020,1641,147,1 24,73, IH FARMALL CUB. 7254, 1863, IH 982
Old 04-25-2014, 04:00 PM
sawdustdad's Avatar
I solved my 149 drive shaft situation a little differently..just throwing it out there for those with fewer skills than Sam...like me.
Old 04-25-2014, 04:28 PM
That works! I'm just being cheap and have the 2000 stuff sitting on the shelf.
