#61
![]() I had a bad noise that I thought was from the PTO and it wasn't. I'll never know for sure if it was the balance gears running on badly spalled shafts or the rough crank bearings. Crank bearings are new and the balance gears are not going back in. |
#62
Well with the pesky engine rebuild out of the way, I could get back to the loader build. Steel prices are high right now, but I was able to find a piece of 12 gauge at a local place that sells crop steel. It had a bulge right in the middle, so I negotiated a good price. As a cheap senior a good deal makes my day and a little press and hammer work took care of the dent.
![]() Getting metal bent here is a costly deal so out came the plasma cutter. And an extra fifteen minutes of welding will save me $100. I waffled quite a bit about the dimensions, but the plate size helped make my decision. I didn't want the bucket overly deep, but still some volume for possible snow clearing. Ended up 22" deep, 18 1/2" high and 42" wide. The box is tacked up and ready to weld. I have a lot of 3/8" X 2" flat bar, so that means that's what the cutting edge is going to be and I'll have to dig around for any bolsters. |
#63
Made some bucket progress over the last few days. My son-in-law works at Finning Tractor and he keeps an eye on the scrap steel bin for me, so I end up with quite a bit of yellow steel that gets repurposed. I like free!!
The bucket is pretty much done except for a bit of welding. |
#64
After the final fit on the quick connect was satisfactory it needed some wire brushing and grinder work. I'll probably use it a bit before painting.
#65
And the first scoop of snow!! I have no weights on the wheels or rear yet, so with a full bucket the one rear tire came of the ground when I got off the seat. I had to dump some so I could take a pic. I put the set of wheel weights I have back on after, but I'm going to need a bunch of weight behind. I better get busy building a sleeve hitch and a weight system. I can see that power steering would be a real asset too.
The loader definitely has lots of speed even at a high idle and plenty of lift. |
#66
Very nice!
![]() But... when it's all fully complete and painted up nice, we need some glam shots!!
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
#67
Way cool Ambush. Like CC107 stated... We need glam shots and a video.
Alan Basket Cases: 129, 1450 sold, 1650 125: 48" Mower Deck, Windbreaker Cab 127: 3 turn steering gear, Spring Assist, Sleeve Hitch, 48" Mower Deck, Dozer Blade 147: 3 turn steering gear, Spring Assist, QA36a w/Xtreme Motorworks Wings |
#68
You have done a Great Job on this.
I like It ![]() You are Truely a Craftsman. ![]() |
#69
Looks real good.
#70
Nice work!
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]() ![]() |
