Old 03-03-2019, 01:20 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Nice job, looks clean. I used the kit on a 126, with tri ribs feels like power steering
-Rick
IH 782
IH 126
CCC 1863
Old 03-03-2019, 07:43 PM
ColoradoCadet's Avatar
ColoradoCadet ColoradoCadet is offline
That what I've heard Rick. I am putting on some narrow tri-ribs too. I am looking forward to feeling the difference. It does make sense that it would turn easier with that bearing on there.
Wayne
Old 03-07-2019, 06:24 PM
For other newbies - good to know that other brand rear wheel weights may fit just fine. Our Sears is going out of business so I got two 55# wheel weights for about $50 plus tax - and they fit like they were made for it.
On the 149 steering wheel, I am guessing the center emblem was just a foil with a sticky back. Is that correct? I cut a piece of steel to fit in mine that I can attach with double sided tape and the new sticker would have a place to adhere to. What is everyone else doing about the steering wheel center emblem?
Wayne
Old 03-07-2019, 08:48 PM
sawdustdad's Avatar
I do virtually the same thing. aluminum flashing, cut to fit. Apply decal.
Old 03-07-2019, 09:00 PM
Thanks, I am the right track then. I cut mine from 14ga steel, hopefully it will stay put.
Wayne
Old 03-07-2019, 09:11 PM
IHCubCadet147's Avatar
I was planning on doing the same for my 149 steering wheel as well.
Old 03-08-2019, 03:15 PM
Temperatures were up today so I decided to do some painting. I have to paint outside. Everything was going really well; working on the third coat of white and "whoosh" a gust of wind comes through and suddenly I have a bunch of crap stuck to my wet paint! Sometimes a fella's patience gets seriously tested!
Wayne
Old 03-15-2019, 04:04 PM
I am missing the springs and spacers for my rear brakes. Does anyone know of a source or something else that can be used. I'm not even exactly sure what the spacer looks like or does? Thanks in advance for any advice.
I gave up and just bought a spring from Ace and shoved it in, hopefully it will work ok
LESSON LEARNED - I have the brakes that don't require a spacer or spring. Thanks to Dart1917 and cooperino for educating me! That is a great relief.
Wayne
Old 03-15-2019, 10:13 PM
I decided I wanted my air cleaner to be a little different, so I painted it black and made a sticker for it. Just wanted to make sure there was no confusion on who made it.
Wayne
Old 03-19-2019, 10:52 PM
Default Basket Pulley slips 1/8 turn
With the PTO removed should the basket pulley be able to shift 1/8 turn? It stops where the holes lines up with the set screw holes, but can move 1/8 turn clockwise. It feels like it locks at both ends of travel, but it shifts with some pressure. The front bearing has not been removed. Thanks.
Wayne
