Old 04-03-2018, 09:37 AM
I want $26 too. I didn't do anything but that's the world we live in today.
I'm from the gubber-mint and I'm here to help
New 2018 EZ tax form,
---just 2 lines
First line:
How much did you make?
Second line:
Send it in.
Old 04-04-2018, 12:39 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Tim... you nailed it!! I have a 16 year old stepson with the same mentality!
Jay
Proud owner of the following:
Old 04-04-2018, 10:32 AM
sorner's Avatar
sorner sorner is offline
My kids think the ATM is a printer, and don’t realize the funds are limited.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 04-04-2018, 07:49 PM
taylorjm taylorjm is offline
Man, at $26 a pop, I would have been better off taking it somewhere to have the work done!!
Old 10-11-2018, 03:06 PM
Rob Yost Rob Yost is offline
Nothing to it. This comes from our tech section.
http://www.onlycubcadets.net/forum/s...ad.php?t=50629
Do you have the manual for it? I think this is it.
https://www.parker.com/literature/27...%20service.pdf
If you didn't order yet, but I think you did, this is the kit to get.
21-SK000011 for $55.53
http://www.messicks.com/part/21-sk000011/sealkit
This link says its for a Steiner, does it work on the Cub 1864 as well?
Old 10-11-2018, 04:28 PM
oly51 oly51 is offline
Looks like it does. See posts 62 and 63 above. I took my 1864 box out today and will be ordering the Steiner kit from Messicks.
Old 10-12-2018, 12:43 PM
Thanks, I didint read all the posts! I'll order it and give it a try!
Old 10-12-2018, 01:56 PM
Excellent thread!
One of the best I have read on this forum so far.
I am fabbing a P/S install for my 149 w/DanCo loader using a 1650 w/109 tower for a test mule. I will be removing the entire OEM hydraulic left setup from the 149 to make the install easier and the 109 tower is a perfect unit to use for a mock-up substitute.
I do have two questions.
The box I have, as mounted and removed from the donor Cub, had the aux port centered at the front.
I have left it there. Will this be an issue in the way the unit operates?? How do I orient the assembly (steering wheel to straight ahead position) so everything is centered when the installation is complete??
So far so good, I believe.
Here are a few pictures in case anyone is interested.
Old 10-12-2018, 03:04 PM
hyperlightboards48 hyperlightboards48 is offline
When I put power steering on my 1450 I found that; The power steering system doesn’t need to be centered, the hand pump can spin I indefenatly if there is no cylinder hooked up to it. That being said the steering wheel will never have a “home” position.
You do however want to make sure you center the turning radius/mount the cylinder properly. So you can turn equally as sharp in both directions. When I did mine I just fully extended the cylinder and the turned my wheels all the way to the left. Marked where the cylinder should be mounted then check the other direction.
Good luck with the install. You’ll love it with the loader.
Edit: you may want to consider leaving the hydraulic lift in place it, comes in handy when additional weight is needed on the rear end
Tanner
Old 10-12-2018, 03:58 PM
Thanks for the reply, Tanner.
The lift will not be needed as the factory DanCo weight box is in place w/400+ pounds in it at present. If I add lead, it can even be heavier.
The rockshaft and lift arms will remain though, as I don't want to screw up the fresh paint on the rest of unit beating that stuff off. The 149 was practically done except for the hood, nose piece and dash when I got talked into adding the P/S. So now, it's back to disassembly once the proto type fab job is finished and all painted up nice.
