#61
It's not running.
Cub Cadet 2166 |
#62
You don't check timing with it running. Refer to the assembly section of the Kohler manual J-Mech linked to. Make sure all the timing marks line up. But if it was running fine in the past, I doubt you have a timing issue.
After you rebuilt the carb, did you verify the spark was present? Something electrical could have failed in the time you were messing with the carb. |
#63
I wouldn't say it was running "fine" anytime recently, but it was running well enough to get the grass cut. Something that hasn't been done since early July. But I'll keep the timing in mind and check it when I finish whatever I'm doing next, which I'm still not sure of. Quote:
Cub Cadet 2166 |
#64
Picture of setting the timing on a 301 that's on a stand, using an external power supply and a home made test light.
I'm not saying that is the single issue, just wanted to know what Wayne knew about the condition of his machine. It sounds like there may be many contributing factors. If you don't know if the timing is correct, and your tractor won't start, ![]() Sounds like it's time to just go through everything and make sure it's all good, you know, like major tune up. Good luck. Now you know why we all have multiple tractors!
#65
We are running again, finally. Not sure what did it but I like to think cleaning up the valves and combustion chamber had something to do with it.
I set my high idle fine but I don't have a tach for setting the low idle and I'm having some issues there (and I have not checked the timing, but I just haven't had "time"). I'm not able to set it low enough where it sounds right, without it dying on me. Any tips for getting it (close enough to) right without a tach?
Cub Cadet 2166 |
#66
