Old 09-04-2016, 10:19 PM
Some models have one at the engine plus one at the trans. The ball bushing should move smoothly but not be loose.
Old 09-05-2016, 06:47 AM
twoton twoton is offline
Originally Posted by vr4Legacy View Post
I've been thinking this over and read another thread that reference 2 ball bushings.
Are there two balls also? I only have one in the back of mine.
Jason, There is only one 5/8" CR steel ball as referenced here;
Originally Posted by twoton View Post
This was my 1650 when I first got it. One rag joint and a 5/8" cold rolled steel ball bearing in the transmission input yoke as it was a pre 622952 serial number machine. I went back with two rag joints and kept the ball bearing in place. Obviously had to get longer bolts. And I did that without loosening or removing either the engine or the rear end.
The 5/8" steel ball is unrelated to the ball bushing as they serve different purposes. The ball bushings purpose is to keep the driveshaft running true about its center line. The 5/8" steel ball is there to keep the driveshaft from moving aft along its length when you depress the clutch pedal.
Any easy way to test the bushings? Just make sure they moving freely like any bearing?
Jeff, as you have both new driveshafts and new ball bushings at hand, would you be able to take some measurements on the driveshaft OD and the ball bushing ID so we could get a better understanding of what would be considered acceptable tolerances?
Old 09-05-2016, 08:16 PM
Driveshaft material is 5/8" and measures between .622 to .625 ( usually comes in at .623/.624 ) The ID of the ball bushing is .625
( I use 4140 for driveshafts. If I were to purchase ground to size 4140P , the prices would jump excessively as that material is three times as expensive )
It's usually the brass/bronze ball bushing that wears on the outside where it fits into the 1.125 ( 1-1/8" ) steel band.
However if it gets extremely dirty, it will wear any or all of the components.
Old 09-05-2016, 09:00 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Thanks for the input Jeff.
I ended up spending more time replacing the floor of my trailer than I would have liked, so the 1200 is likely delayed a week or two.
But I'll report back with my findings.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
