#61
Jason,
This is the tach I use; https://www.amazon.com/dp/B0044AV5VK...I2ZABVGKPU4NPF http://www.onlycubcadets.net/forum/s...&postcount=191 It's called a vibra tach. Works well. ![]() David |
#62
Thanks for the link David.
Here is what I'm looking at https://www.amazon.com/Docooler-Tach...ive+tachometer I like the fact it's inductive, seems simpler to use. And I might hook it up permanently as an hour meter. Plus it's cheap ![]() Thoughts?
-Jason Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54 Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks Gravelys 5260 | CI Walk-behind (Project) And a couple of Subarus ![]() |
#63
Looks good Jason, cheap and Prime!
![]() Let me know how it works. |
#64
Your carb looks like this, right? Except maybe not so dirty..
#65
![]() Quote:
![]() I adjusted the other two per the service manual for initial settings. I just need to get the tach and warm the engine up. However, I need to fix my oil tube first. Any thoughts on that? Should I put some RTV on there?
#66
I did some research (googled this site
![]() I also got my muffler heat shield and side panels on. Fired it back up and checked everything out. Oil doesn't leak anymore. I drove it a few feet forward and back and it seems to move fine. A little jerky, but I need to check the hydraulic fluid and change the filter. I'm guessing I'll need to go through the linkages and check things out too. I probably should have done that with the fenders off ![]() PTO rebuild parts came in today. And the tach should come tomorrow (gotta love Prime shipping) But I still have a few things to do around my house that I had planned for my "vacation". I'm out of town this weekend so I should probably get those done to appease the wife. I'll likely get back into the 149 in a week or two, but I'm pretty happy with the progress thus far, and it appears this thing is gonna be ready to roll. Thanks everyone for the help!
#67
Thanks for the update!
#68
I cleaned up the PTO pulley some and painted it white.
Does anyone know what the color scheme was from the factory? I can tell the pulley and screws were white, but how about the throw out levers. Looks like mine weren't painted. Hopefully I'll get it put together this week and back on the tractor. Maybe I'll take her out and mow over labor day... just need a seat now.
#69
I got all the parts out of the PTO rebuild kit and I can't figure out what these clip things are for. From what I can tell from the instructions, the snap ring and washer are for newer PTOs with a brake. Are these clips for later PTOs too? I didn't have any on my old PTO.
I painted the button and springs. This thing is gonna be purdy.. ![]()
#70
The three matching springs are "anti rattle springs" that go in between the PTO basket and the PTO disk. Depending on your patience level, you may invoke the "universal adjective" while trying to install them.
