#61
Congrats!!
#62
John Proud Owner of a Model 100 and a Model 124. A homemade cart, 2 x 42" mower decks, a 38" deck, a 42" front NF blade, and a lawn sweeper! |
#63
Congrats on getting it going!
![]() Can't wait to see the pics! |
#64
Thanks for the praise, guys! It would have been a fairly easy swap, but the 86 and 800 have different crank lengths (a feature of the 86, which has longer crank), plus the 800 has a tapped hole in the center of the crank for the PTO. Hard to say how many people would have done that I suppose...
#65
Nice work.I did somthing similar putting a QL motor in a 100.
I never looked at the pto on my 800.I thought it had the 4 threaded holes in the block for the pto.Does the 86 block have the threaded holes in the block also?
#66
Yep, the block had the four holes for the PTO. I made sure of that before I tore into it...one does not want to forget the spacer that goes in between the crankshaft seal and the PTO.
Really its a direct swap as far as the block. It was just time consuming pulling the crank, re-timing the gears, pulling the flywheel off both engines and pulling all the stuff off the 86 crank to get it off (basket pulley and mechanical PTO). the only other time I had to do this was in a 122 when I needed to switch cranks.
#67
thats good on you 800 I was wonding if you would sale the 86 crankshaft the spacer on the top stater bracket
#68
JLM78-PM me. Hopefully you get to Iowa every now and then.
#69
Please place a want ad in the wanted section of the site with your parts needs.
#70
thanks I am not looking hard of the part I just see he had one was all
