Old 01-28-2013, 11:35 AM
Sam S.'s Avatar
Sam S. Sam S. is offline
Looking sharp!
Sam,2-149,102-with creeper,102,125-parts,147,682,682-Cub Ca-table,1440 4cyl-(work in progress),3165,154 lo-boy with 3 cyl. diesel, Shed full of parts and accessories
Old 01-28-2013, 11:54 PM
jlampe94's Avatar
jlampe94 jlampe94 is offline
Well got the pump put in tonight and looks like itll work so now down to reservoir and lines.
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4.
Old 01-29-2013, 12:53 AM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Awesome set up can not wait to see it working
Don Smith
Old 01-29-2013, 02:03 PM
Same here!
Old 02-03-2013, 07:27 PM
jlampe94's Avatar
Makin progress! Reservoir is is made now just need to figure out how i want to mount it in there. Also need to make a cap. Got lines measured out so now just need to get those made. Should have it workin by the end of the week
Old 02-03-2013, 10:03 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Looks good!!!
Old 02-03-2013, 10:29 PM
CadetTY's Avatar
CadetTY CadetTY is offline
What exactly is the pump out of? You said s10 any year? Anything i need to look for. I might try the set up some day
882 diesel, x3 ih 582, 73 124, x2 82 seriers pullers, 1686 16hp puller
Old 02-03-2013, 11:09 PM
Nice work!
Old 02-04-2013, 01:43 AM
ajcombs's Avatar
ajcombs ajcombs is offline
Well while i think it looks awesome i have some concerns that I'm thinking might hurt the longevity of your pump. The air that cools the motor is now blocked by the tank some but don't think it really is enough to harm the engine, i would the the extra heat would cause the oil to probably almost boil as close as it is to the muffler. Am i seeing the picture like i think or missing something? What if you mounted it over the head just out of the way of the spark plug?
Only trying to help it looks awesome and good luck!! Duke i think this guy can make u a reservoir our for your loader
Old 02-04-2013, 11:53 PM
jlampe94's Avatar
Thanks guys, got the reservoir mounted in tonight. The pump is out of a 154 loboy i was originally going to go with a powersteering pump but this ended up easier to find and cheaper. As for cooling the pump is below the air flow and i placed the tank above the air flow so the air cooling part shouldnt be a problem. As with the muffler im gunna put a shield in between the two, hopin thatl take care of most of the heat and keep the oil cool. I thought about above the head but i wanted it out of the way for maintance. We'll see how it goes when i get her workin. Thanks for the input.
