Old 12-03-2012, 05:54 PM
JayJay JayJay is offline
John: I receive your comment as a compliment. You helped me understand and remember that only a collapsing (or building) field in the primary will induce a voltage in the secondary --exactly like a transformer on AC current. The points' opening is the trigger event: my thinking was very cloudy on that point.
There is a proverb that goes something like, "Like flint to steel, so one man's mind sharpens another's."
Thanks for posting.
Jeremiah
Old 12-04-2012, 12:53 AM
Wild Bill's Avatar
Wild Bill Wild Bill is offline
Timing being 'off' is blamed for a multitude of other issues that are the actual problem........
Carb dirty/partially plugged, or out of adjustment.
Valves out of adjustment.
Weak coil.
Bad/incorrect type spark plug wire.
Loose/dirty electrical connections at condenser, coil, etc.
'Other'.
A combination of these........
These issues will cause an engine to not run smoothly, not gain RPMs, not idle properly, skip/miss/hiccup, etc
Original OCC Super Mod....and former OCC Co-Admin.
I was hacked........
Old 01-07-2013, 09:55 PM
CC1650Dave's Avatar
I did manage to finally get a new 44A deck for my 1650 project today.
If you don't recall, I broke mine down and took the big parts to the sandblaster last year, and he had me drop it off in front of his shop. It was stolen from his property, apparently.
After a long struggle to get him to find me a replacement deck, I finally found one on CL that the guy delivered to his shop, and he paid for it.
I just picked it up this morning, and the good news is that it's in better shape than the one he lost! The housing and belt covers are in very solid shape.
So now I still have (I think) two good spindles from the old deck to keep as backups.
The bad news is, it's all going into storage tomorrow until I can get a place to get back to work on it again.
Old 01-08-2013, 09:29 AM
Dave thanks for the update! Good luck on your move.
Old 01-08-2013, 12:05 PM
Good to hear from you, Dave! Thanks for updating us!
Old 01-20-2013, 07:48 PM
CadetTY's Avatar
CadetTY CadetTY is offline
Cant wait to see you start the body work and some color! Great build tho!
882 diesel, x3 ih 582, 73 124, x2 82 seriers pullers, 1686 16hp puller
Old 01-21-2013, 07:12 PM
Daddysignman's Avatar
Daddysignman Daddysignman is offline
i thought i had a timing issue as well and i spent so much time on getting the timing perfect and figured the carb was fine until a buddy brought his carb over and we bolted it on and she ran like a champ.
I cleaned my carb and rebuilt it and it was just not meant to run well again. the are real precise pieces and if its worn or not put back together correctly you are going to kill yourself trying to fix it.
so if you can swap a good known running carb on her and try that you can save yourself some headaches. though those headaches are what really make you learn!!
Good luck
1977 1450 Hydro -At the Shop! and a 582 Special on torn down on the bench. QA42A, 2 44 decks, snow blade, trailer.
Old 01-22-2013, 04:45 AM
OldSchool81's Avatar
OldSchool81 OldSchool81 is offline
Nice progress on the 1650. It's a crying shame that people scrap such wonderful machines. You did the right thing by saving it.
Old 01-22-2013, 06:16 AM
Old 01-22-2013, 01:10 PM
Welcome to OCC! You got that, right!
