Old 11-17-2018, 05:25 PM
cooperino's Avatar
Either should be fine providing the old one is still good. And that the new one is not so thin that it makes linkage and other parts not have correct clearance
Old 11-17-2018, 05:46 PM
35boulder's Avatar
35boulder 35boulder is offline
Thank you sir. Would you know of a diagram that would show all the grease fittings on a 100? Would really like to get this all lubed up while I have a chance.
Thanks Dave
Old 11-17-2018, 07:14 PM
cooperino's Avatar
In the tech section here you will find the manuals for the 100.
Heres a lonk to the chassis service manual
https://www.onlycubcadets.net/forum/...ead.php?t=4640
And heres the operators manual
https://www.onlycubcadets.net/forum/...ead.php?t=4667
Old 11-17-2018, 08:34 PM
35boulder's Avatar
Thanks for the heads up on the manuals. Should help a lot. Thanks Dave
Old 11-17-2018, 09:09 PM
If the original gasket is still in good shape ( good surfaces on both sides), it should be acceptable to reuse
Old 11-18-2018, 08:06 AM
twoton twoton is offline
Originally Posted by 35boulder View Post
Hello. So I purchased on of the #26 carburetors that was mentioned in an earlier post. Noticed the gasket is no where near as thick as the one on the original Carter. Will this be a problem? Should I just reuse the original or look for a thicker one? Thanks for your help. Dave
I know that my Quietlines use the thicker thermal isolation gasket (part # 47-049-01) to help reduce heat transfer to the incoming fuel. Wouldn't think it would be a problem to use it on your tractor. If you're concerned about it sealing properly, you could put a THIN film of some sealant on the mating surfaces. Like this Permatex Anaerobic Gasket Maker;
https://www.amazon.com/dp/B0002UEONM...542541906&sr=1
Remember, air leaks at the carb can draw dirt into the engine, promoting premature engine wear.
Old 11-18-2018, 11:39 AM
35boulder's Avatar
Well, here's another question to throw out there. As i'm looking over this 100, I am wondering, are the tie rod ends the same as the ends on the steering arm that connects to the front end. Are these end prone to needing replaced after all these years? Thanks
Old 12-09-2018, 05:59 PM
35boulder's Avatar
Just wanted to update the progress on my 100. Thanks to all for your help and especially Bill Cooper (Cooperino). As of today the 100 starts and runs. Now that I have the "go" I'm needing work on the "whoa". Brakes all but non existent. But again I wanted to say thanks to all for your help and encouragement.
Any suggestions on the on the brakes would be great. As I depress the clutch/brake pedal the brake lever hardly moves.
Thats it for now.
Old 12-09-2018, 06:39 PM
There is a procedure to adjusting the brakes in the manual, pretty easy, unless something is broke or worn out it should take 5 minutes.
Old 12-09-2018, 06:59 PM
35boulder's Avatar
Will give that a try. Thanks
