Old 03-04-2017, 09:33 PM
tinkerman tinkerman is offline
I know.... the straps should have been yellow. Was trying for unique, but don't really like it. Probably will change
Old 03-04-2017, 11:18 PM
I bet you're chomping at the bit to light it up. Good luck!
Old 03-05-2017, 12:51 AM
Yes sir, indeed I am. Maybe Tommorrow if everything falls in place. Kind of nervous about the governor. Followed all the directions, but there is zero tension on the spring. Just doesn't feel right. Gonna look into it some more Tommorrow.
Old 03-05-2017, 01:41 PM
Ok, went over everything again this morning. Wasn't sure about how the throttle set up would work without it being installed. So I just set the console from the parts tractor and hooked it up. I set the battery on the table, hooked a Hotwire from + side of battery to + side of coil. Used booster cables and hooked negative to negative on battery. Other end of negative to a ground point on block. Then took positive side of jumper cables and hooked to positive side of battery , other positive end to "A" terminal on starter and HOT DIGGETY DOG!! The son of a gun started and ran!!!! ...... gotta make fine tune adjustments to the carb, but may wait till I put it in tractor to do that. (It's not anchored down right now, and inside) AWESOME!! 😜😜🚜🚜🚜 sure wish Austin coulda been here with me
Old 03-05-2017, 02:07 PM
PS no knocks at all , very smooth
Old 03-05-2017, 05:21 PM
Looks great Tinkerman. Good feeling getting one to run after it's been apart for a while, and no issues that's always a plus. I'd say the hardest part of the build is over.
Old 03-05-2017, 05:48 PM
Thanks alvy, the engine really wasn't that difficult, with the exception of crank end play. Removing the bearing plate without a puller was aggravating. If you go by the manual, DONT GET IN A HURRY, and don't look at it as a "job" it's actually pretty interesting. I hope to do another one soon. Got the clutch back together. Man there's a LOT of tension on that clutch spring. Didn't realize it when I was taking it apart. Hope some of what I'm doing helps someone else
Old 03-05-2017, 06:05 PM
Congrats on your rebuild. You are very meticulous with your work.
Up to 534 and counting...
Old 03-06-2017, 11:20 AM
Before and after
Old 03-06-2017, 02:12 PM
Dirty Steve's Avatar
Looks great!!! You are giving me courage to see mine through. Thank you!
