Old 11-25-2016, 11:35 PM
That dash looks to be in good condition, bonus.
You'll go broke buying those little cans of paint...
Old 11-26-2016, 10:50 AM
johncub7172's Avatar
Smile
Thanks zippy1! Oh boy, I'm not going that paint rout, lol! I was in Drug Mart with my wife when I seen that yellow enamel. I just used it for the weld on the muffler brace. The color really is not all that bad. I'll have to get a pic of it!
John Hall, Yea-buddy! The 125 is much closer to being able to operate. I'm dying to hear it start up. Once it's together, I got to make room in the cubby garage for the model 86 I have!!!!
Old 11-26-2016, 10:28 PM
Default Repaired 125 muffler brace/shield
Here is the muffler brace, / heat shield that has been welded to a repair. I then cleaned it up and hit it with the Testor's Yellow paint. The color match is pretty good.
Old 11-26-2016, 10:39 PM
Exclamation Voltage regulator wires need identified
Here are the leads that run to the voltage regulator. I lost my pictures to the correct connection terminals when I tipped over our canoe this summer. I'm looking at these hard to determine correct installation.
Old 11-26-2016, 10:46 PM
Default Did not get to achieve spark today
So I had planned to get spark today in hopes of hearing the 125 "pop-off" ! I had figured I needed to clean a bunch of parts and components first:
So I went down to my local wally world, and for $8.47 I got this:
I had a 3" paint brush, a wire brush, and a old tooth brush, and some scalding-hot water. Here, the cast iron grill is dirty:
Its dry now:
Old 11-26-2016, 10:53 PM
Default A few more to get the idea
Here is the headlamp panel:
Cleaned:
I went on to clean more parts for this assembly. This Goop is a great way to clean parts! Also, cleaned all IH stamped hardware with the wire wheel.
Old 11-26-2016, 11:00 PM
The headlamp panel is on the 125!
Got the hood cleaned up too. This is where I left off for today. Going to try some more tomorrow!!! Dying to hear this 125 start!!!
Old 11-26-2016, 11:47 PM
Holy smoke, it cleaned up real good.
Be careful wire wheeling the IH bolts if that's the hardware you're referring to. You can take off the coating, and after the bare metal get's wet or damp enough times they's turn to rust.
Old 11-26-2016, 11:49 PM
Your 125 is looking sharp, John!
Old 11-27-2016, 08:16 PM
Cool First Fire!
The 125 has spark and since has fired over! I believe I have the voltage regulator correctly figured out!
