#51
thanks all for the compliments. It does feel good to finally see a little bit of it coming together. I didn't get much done tonight, even though there's plenty to get done yet. I did pick up my engine/clutch adapter and my front pedestal should be done in a day or so. I've got a bunch of parts on order that should be here in a couple of day's. snow's melting fast, crunch time is coming!!
#52
If you get a second can you post some pics of the clutch adapter?
#53
This appears to be one well thought out, well executed build.
122 original, well used. Owned since 1972 2182 new to me. Refurbished and gave to my son. Deere 4300 4WDA HST with FEL Many old Ford tractors, all gone now Couple old Ford trucks |
#54
here you go sam, it's not anything special but necessary to mount the clutch driver to the mount that came on the engine from the 1641. it is .5" thick and drilled to match the mounting pattern on the clutch driver.
clutch driver and "adapter" ![]() driver and adapter put together ![]() mount that came on the engine from the 1641 ![]() |
#55
with the beautiful weather and the few parts i'm waiting on progress has been slow going as is my usual. I did get my linear actuator in and mounted.
![]() ![]() what surprises me is it actually works!!!!!! ![]() ![]() |
#56
Wow that is a cool rear lift. Excellent work. Now turn some dirt and let us drool on the screens some more!
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
#57
Hey can anyone recommend a good seat that'll look good on this? I would prefer it had the cub bolt pattern. Thanks
#58
these seats are real nice and have the correct bolt pattern.
http://www.ebay.com/itm/NEW-SEAT-FIT...item51cfff4593
#59
thankyou sir. I just ordered one.
#60
hey guy's I've been slow on the updates and almost as slow on the work. I finally got my front axle parts, and inside wheel weights from the machinist. which let me get the front tires on along with some cosmetics. I got a little paint sprayed and decided to take a couple more pics. I tried mounting up all of my rear weight's but bought some crap carriage bolts from tsc and snapped three of eight bolt heads off. my new seat showed up today so that'll be going on tomorrow after I pick up a load of piglets. I need to get the front weight bar done up quick. i'm hoping to be turning some dirt real soon if I can figure out the wiring for this engine!!! oh here's some pics, don't mind the dust!
