Old 05-03-2014, 08:25 PM
Took the clutch out, some of the parts are worn At least the clutch shaft is in pretty good shape. I will make some new pins for the driver and the yoke.TO bearing will be replaced and a newer clutch disc.
pictures for the forum...
Old 05-03-2014, 08:37 PM
Wow lew that clutch has seen much better days, it's worn out , just a little.
Old 05-03-2014, 08:45 PM
Yes nick it is, what, it is
Old 05-03-2014, 08:48 PM
Repair time Lew!
Sorry to hear you came home empty handed.
Old 05-03-2014, 09:28 PM
It sure is.
Old 05-03-2014, 10:21 PM
red56turbo's Avatar
I'd say they got their money's worth out of that clutch. You'd think they woulda looked into that banging/screeching noise and the fact the clutch wasn't working very well. Gotta love some PO's, geesh!
Josh
Diesel Cub Cadets...........
Old 05-03-2014, 10:23 PM
That clutch has definitely seen better days.
Old 05-04-2014, 12:58 AM
WOW. I don't know that I've seen one wore quite like that. I'm with Josh, you would'a thought that the PO would have looked into that noise!
Old 05-04-2014, 08:17 PM
It is what it is....
I got a little free time today to remove the 2 ball bushings. The one on the rear coupler came out easy, pressed in a new one, the front was a little more involved, cut a slot next to the splice that is from the factory, it closes up when it is installed, and was able to pry the old one out.Cut it with a new tool I made out of a hacksaw blade.
These bushings are made by triange mfg.$5 a piece from them,$25 from cub cadet and those are stamped triangle, oshkosh wi. on them. Go figure.
Old 05-04-2014, 08:35 PM
Good job lew.
