Old 07-26-2013, 08:50 PM
eric kancar eric kancar is offline
fixed the leaking carb but still only runs 2-3 seconds...
Old 07-26-2013, 10:47 PM
Do you know if you are getting gas into the carb? Have you changed the fuel filter? How old is the gas? Have you disassembled the carb and cleaned it inside and did you get every little passage and orifice clean?
No I'm only gonna say this one time. If you do not know what you are doing with a carb you can screw it up. If you keep trying to run the engine on starting fluid you will blow it up and then you will get to buy a new engine.
Do you have the service manual for your engine if not go to the Kohler web site and down load it, it tells you how to fix your engine.
Old 07-26-2013, 11:10 PM
Thumbs up
thanks sam, i'll answer each below in red:
Do you know if you are getting gas into the carb? when i pulled the carb off plenty of gas came out of it so I assume it is getting into it okay.
Have you changed the fuel filter? I cleaned the one that is on it only because I didn't have a new one yet. Will pick one up tomorrow. It was full of brown crud.
How old is the gas? couple weeks at most
Have you disassembled the carb and cleaned it inside and did you get every little passage and orifice clean? it honestly didn't seem dirty at all and all the passages and orifices seemed clear of any debris. I was expecting a lot of grime in there
No I'm only gonna say this one time. If you do not know what you are doing with a carb you can screw it up. If you keep trying to run the engine on starting fluid you will blow it up and then you will get to buy a new engine. I hear ya loud and clear! The carb went back together nicely. There is one little tiny pipe (small, only a paper clip would fit in it) that goes up into the center of the carb. I would have expected it to be exactly centered but it is offset. Wasn't a movable piece so I am guessing this is correct. I will check the service manual on the kohler site as I was already looking at that.
thanks for your help!
eric
Old 07-26-2013, 11:35 PM
Question
Because I tried a new ignition module (aka mag) i took off the old one but realized after the fact that this was not the issue. Old one worked just fine. I set the gap best I could but wonder if it is correct. In the kohler service manual located here: http://www.kohlerengines.com/onlinec..._20_690_01.pdf
i don't see anything on page 36 where it talks about the module about what the gap should be. It seems like since that system is constantly firing an electromagnetic current if not just right that it could cause the engine to start briefly (so far only with starter fluid) and then stop running after 2-3 seconds. This assuming that the carb is clean since is did my best to clean it.
Let me ask you this as well. The carb solenoid must be working since the engine runs for at least a brief period right?
Thanks
eric
Old 07-27-2013, 12:59 AM
No. It is running off starting fluid.
Eric, I think I can say we really want to help, but I believe you may be in over your head.
Old 07-27-2013, 01:34 AM
ok, thanks. I'll stop posting questions and seek help.
Thanks for all your help, really appreciate it.
Old 07-30-2013, 06:44 PM
Thumbs up DONE and RUNNING!
Turns out it was the carburetor solenoid. The guy who fixed it said they often overheat and go bad. It was a manufacturing defect because of the close proximity of the muffler causing it to overheat. The replacement kits that you buy include a heat shield for that area. Makes sense. Too bad as this would have been the piece of the puzzle that I would have gone to next to replace. Thanks for everything! I learned a lot!
Old 07-30-2013, 08:48 PM
Glad to hear that you got it going!
Old 07-30-2013, 11:04 PM
Good to hear!
Old 07-31-2013, 11:53 AM
Great news!
Tags
battery, engine wont start
