Old 06-28-2012, 12:48 PM
Sugarmaker's Avatar
Doug,
That new lever is slick. Great fab work! I like the position. If I had hydraulics on the 125, I might trade off the old 147R Can you still get these hydraulic units?
Nice work!
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 06-28-2012, 01:49 PM
Doug,
Nice work!
Chris
Chris Yes you can.
Doug the handle looks great! That's the weakest link of the hydraulic add-on.
Old 06-28-2012, 04:30 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
thanks guys, Im trying to work on the dash and hood now. it just to hot. Sat is going to be cooler... maybe tonight?? somthing like 70 tonight. has to be done by the 4th so I may try working on it later.
Doug
Original , 100 , 125 , 582
Old 06-28-2012, 10:14 PM
4SPEED's Avatar
got them ready for sealer. the hood is as slick as glass. I epoxied it after I stipped it and acid washed it. 2 coats of filler primer between its flash time. 220 blocked that. used filler in a few small areas. 2 coats of high build primer 220 wet sanded, then switched to 400grit wet. dryed it off and sprayed 1 coat of the high build primer on it. only added more reducer to it to thin it. just wanted to fill any 220 marks I missed. then 400 grit wet sanded it again. I'll wipe it down with wax/greese remover before I put the sealer on it. and paint. sounds like a lot of work but it only took 4hr to get the hood ready.
Doug
Old 06-28-2012, 10:34 PM
Thanks for the awesome pics, Doug!
Old 06-28-2012, 11:35 PM
That hood is going to look so shiny
Nice work on the 125.
Up to 530 and counting...
Old 06-29-2012, 11:01 AM
EarlJ's Avatar
EarlJ EarlJ is offline
Doug you can drive down to SC and do my 126 for me. You do some very very nice work...Just curious what is that scoop pan looking thing hanging off the front?
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 06-29-2012, 11:14 AM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Looks good Doug
I'm pretty sure that's for a front mounted generator
Old 06-29-2012, 01:02 PM
4SPEED's Avatar
yep its a front mounted generator. it off getting new bearings, well its done and setting in the back of my truck.
got the hood and dash painted early this morn.
also had to pull the steering column out so I get the rubber donut ring off to clean it and to put the dash back on. then slide the column back in the rubber once the dash is on.
Doug
