Old 03-20-2012, 09:39 PM
The slotted end bars are for floating capability and bars with a single hole apply down pressure. I would go with the slots.
Old 03-20-2012, 09:59 PM
Holy cow, your going to town on it.
Looks real nice.
Old 03-20-2012, 11:03 PM
Try this.no slots but you have a template on your bench?
Old 03-20-2012, 11:47 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
thanks for the pic. that will work just fine. you guys are the best....
Doug
Original , 100 , 125 , 582
Old 03-20-2012, 11:53 PM
Looking tough, Doug! Love the rear ags!
Old 03-21-2012, 04:41 PM
4SPEED's Avatar
I got the spring lift assist installed. made and test fitted the lift bars. put the 10" plow on it , so to adjust the spring.
Doug
Old 03-21-2012, 05:24 PM
Doug everything looks great! For a moldboard plow you'll want to put slots into your lifting straps.
Old 03-21-2012, 05:47 PM
Looks great, Doug! You'll be ready to plow in no time!
Old 03-22-2012, 02:54 AM
4SPEED's Avatar
got some new dash parts , and started work on restoring the dash.
found the fuse parts in a computer control panel. they are better duty then the ones I took out.
the the hood was cutting the dash a little , so I filled it with fiber glass.
ones I put the resin and glass mat on it , I put painters tape over it to rub out any air thats under the resin. let it set up and pull the tape off (slowly)
tomorrow I'll sand it , fill any pin holes with glass filler and prime and paint it.
Doug
Old 03-22-2012, 11:42 AM
You go Doug! Looking good, kinda makes me envious that your that far and you just got started a week or so ago, and I'm not half way to where you're at on my 100.
Must be the drive, my drive has got up and went
