#51
Gary
Your drive shaft flange just should bolt up to the adapter. You may need to play with the shaft length but that should be it. |
#52
Gary
The flange on your drive shaft should just bolt up to the adapter. The bolt pattern should be the same. It was on my 1210. |
#53
A few things got done today. As you can see I got the engine mounted but first I had to build a 3/4" riser to line up the driveshaft height. I used the old Kohler block,crank and adapter coupling as a reference. The PTO clutch bolted right up with out any problem, except my so call basket case Kohler engine was missing one stud bolt for mounting the clutch. That shouldn't be a problem. The choke cable is long enough but the throttle cable will have to be extended. The starter on the Briggs is on the right side so I will be extending the starter cable too.
DSCF1197.jpg DSCF1198.jpg DSCF1196.jpg DSCF1199.jpg As you can see I still need to figure out the driveshaft hook up. I think I'm going to be extending it beings the crank is about 4" shorter than the Kohler.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake |
#54
Looks real good!
![]() The red really sets off the motor.
Jed Proud to be a FFA member Westmoreland,TN Chapter 1978 Cub cadet 1450 IH Hubcaps 1975 1650SGT Work In Progress 1974 cub cadet 129 with sleeve hitch/spring assist 1974 108 (Mint) #510358 brinly 12 in plow,disc,8 in plow ,2 42, 2 44A ,50A DECKS #40 boxblade,can`t keep up with the rest lol ![]() ![]() ![]() ![]() |
#55
I agree with Jed!
#56
The flywheel-to-driveshaft adapter from a 1641 or 1440 should work. Don't forget the flywheel screen, too.
#57
Great pics, you've been busy!
#58
she's looking good Gary. love that big V
PS. send me your info. so I can send you that rubber conveyor belt, we talked about.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
#59
Gary
As Matt said the adapter from 1440 or a 1641 will work as will any of the adapters used in the 2000 series with Briggs engines. That's why I gave you the part numbers from a 2160. You will need to make a longer drive shaft. I'm sure Matt can tell you how to do it the easy way. Sam |
#60
That tractor is looking sweet!
