Old 08-28-2011, 09:50 AM
Thanks for the update pics, Chris! The Tru Powers will look awesome on your cub!
Awesome pics Chris! You really hooked us up on the pic updates! Your painted parts look so nice! How do you like the paint remover? How long does it take to remove the paint?
Old 08-28-2011, 09:53 AM
Sugarmaker's Avatar
Default more pictures of the 147R
Wasn't sure how many pictures I could post at a time so there will be multiple posts here
Hope this helps you on one of your CUB projects! I sure have learned a lot about narrow frames!
At this point I think I am about 60% complete.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 08-28-2011, 10:20 AM
Sugarmaker's Avatar
Default Yes we have more shots of the 147R
I am getting a cramp in the mouse hand
Hard work loading resizing and loading these!
Here you can start to see that I am turning the corners as some new paint gets applied here and there.
BTW Rustolem Sunrise Red cans have a problem They will spray 10% in the correct position and then have to spray the remaining portion in the inverted position. Not kidding!
Regards,
Chris
Enjoy!
Old 08-28-2011, 10:54 AM
Sugarmaker's Avatar
Site went down during last post.
Methos,
Paint stripper works good. Was it you that gave me that tip? It was a good one!
More shots.
Regards,
Chris
Old 08-28-2011, 11:01 AM
Sugarmaker's Avatar
Default Just a few more for today:)
This will be it unless I can pry some off the camera today!
Hope things are good in Cub Land!
That picture with the ags from the back was the "look" I was after! Thanks guys for the push!
Anyone notice that I drilled the two center holes wrong in the new trunk base?
Woops! Not changing it now! Its welded in place! Next owner can yell about the work of the "PO"
Regards,
Chris
Old 08-28-2011, 04:22 PM
Very nice, Chris! Can't wait to see your 147 finished!
Old 08-28-2011, 07:26 PM
bocephus1991's Avatar
Looks great! Can't wait to see it when it's all done! Great job!
Brian
Old 08-28-2011, 08:00 PM
Looking good! Don't forget to clean the paint off of the aluminum part of the hydro pump...
Old 08-28-2011, 09:44 PM
Sugarmaker's Avatar
Matt,
I did not think about that. I assume the paint might restrict the heat dissipation from the hydro unit? That may be a challenge to remove the paint at this point? I will take a look at it. I may be able to get some removed with the seat pan off.
Thanks Guys for the comments.
Yes I know its not yellow and it will be far from perfect. Maybe a good 20 footer But hopefully will make a good reliable tractor to use around the yard. And have some fun with too.
Thanks
Chris
