Old 02-07-2012, 01:54 PM
TheSaturnV's Avatar
Hear ya Dave, my Sears Suburban project has had its number of stalls, but I've never quit entirely. I need to get my shop heated as well.
Old 02-07-2012, 02:36 PM
Flatbedford's Avatar
This is why I am always afraid to start a project like this. I hope you get back into it. Whether you finish the tractor or not, you have given us all a huge amount of information.
Steve,
Former multiple 149 owner.
Old 02-12-2012, 01:36 AM
CC1650Dave's Avatar
[QUOTE=Mike1450;114820]
Originally Posted by Mike1450 View Post
I also noticed this statement in a earlier posting "c) Just a note for reminder, in case it strikes anyone as problematic: When I initially put the points @ .020, they break at TDC, when the "T" is in the sight hole. I have to bring them all the way out to around .040 to get them to break at the "S." "
If your are out at 0.040 with your points this seems to be very excessive. I would expect a normal range to be 0.015 - 0.025. The 0.040 may also indicate you are off by a tooth.
Yeah, I thought that was a key observation Mike, thanks for the feedback.
I just can't believe I left that thing off by a tooth. How frustrating. I had to pull the crank and put it back in several times to get the shimming right on the bearing plate, and each time I ogled those darned alignment marks until I was cross-eyed. Guess the last time got me. aaaarrrrgh.
Old 02-12-2012, 11:29 AM
Sugarmaker's Avatar
Dave,
We are here for you.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 02-12-2012, 02:42 PM
That's they way things often go for me. At least you know how to take it a apart and put t back together. With all that practice it should be pretty easy for you.
Steve,
Old 04-09-2012, 08:53 PM
CC1650Dave's Avatar
Default Back to work
OK fellas, time to get back to the project. Nothing motivates me like having to push-mow my lawn again...
So I need to pull the K341 back out of its temporary home in the 1450, to open it up and check my timing / crank alignment.
I'm assuming I'll need to buy a whole new kit of gaskets and seals to do this, even though the last ones have really only run 20 minutes.
Agreed? What about the head gasket? It's the Kohler OEM and cost $17 or so, and since it wasn't run much I'm thinking I can still use it rather than replacing...
Old 04-09-2012, 08:58 PM
Dave Welcome Back!
You've spoiled us!
Old 04-09-2012, 09:08 PM
Welcome back. Look forward to more on this.
Steve,
Old 04-09-2012, 09:12 PM
Glad you're back! Looking forward to your updates.
Old 04-09-2012, 09:14 PM
I wouldnt worry about the headgasket, if its only been run a few minutes its not enough IMO to worry about replacing. I usually torque it down 1 or 2 ft pounds more for peace of mind
Some of the engine gaskets may need replacing, depends if you use gasket sealer on them or not. If you did, Id avise replacing them. If you are careful, you might get by without replacing seals. Just my .02. Ive been in the same boat, the best way to learn is to learn from your mistakes when it comes to Cubs and engines.
